05redLGT Posted December 14, 2016 Share Posted December 14, 2016 Long time lurker, need some help. So the inevitable happened, turbo blew along with the oil control valve. I know this topic has been beaten to death here but there's still no real answer on why it happened. Banjo filter was clean, oil done regularly. Not sure if oil control valve was the cause of the death of my turbo, either way, new turbo going in this week and everything else fixed. If anyone has any input on why this happened, I would be really appreciate it. If i knew the actual cause. I would like to fix it permanently, otherwise i will sell the car i just simply dont trust it to not fail agian. Also, does anyone have a link to the order of the crush washers that go on the coolant and oil lines for the turbo? that would be a great help. Thanks in advance Link to comment Share on other sites More sharing options...
Rhitter Posted December 14, 2016 Share Posted December 14, 2016 It's an 11 year old car and nothing lasts forever. My OBXT build Link to comment Share on other sites More sharing options...
The 2Fiver Posted December 14, 2016 Share Posted December 14, 2016 some of these vets are getting a little bitter Welcome to the forum New guy Link to comment Share on other sites More sharing options...
05redLGT Posted December 14, 2016 Author Share Posted December 14, 2016 ha! thanks, im getting pretty bitter myself, especially my faithful steed failing before the winter... thing is, its the 2nd turbo in 2 years... it was like 12k miles old, so there's something.. Link to comment Share on other sites More sharing options...
The 2Fiver Posted December 14, 2016 Share Posted December 14, 2016 Yeah I can't help you much further from what he said tho. Motor seems to be a turbo muncher at that rate. Link to comment Share on other sites More sharing options...
Holla Posted December 14, 2016 Share Posted December 14, 2016 Any idea what sort of oil pressure you have during normal run conditions? I'd drop the oil pan and look at the pickup, they've been known to fail but they also generally take out the bottom end when they do. What about the oil lines to the turbo? Were they replaced? Link to comment Share on other sites More sharing options...
Gigs Posted December 14, 2016 Share Posted December 14, 2016 If its your second turbo in two years there is a problem. Turbos just don't die randomly as much as the hive mind would like to tell you there is a cause and effect for all parts failures. Could be - Poor oil change intervals - Poor oil quality - Low oil levels - Clogged banjo bolt filters Link to comment Share on other sites More sharing options...
Rhitter Posted December 14, 2016 Share Posted December 14, 2016 This is why it died - http://legacygt.com/forums/showthread.php/turbo-failure-wiki-173358.html My OBXT build Link to comment Share on other sites More sharing options...
05redLGT Posted December 14, 2016 Author Share Posted December 14, 2016 Any idea what sort of oil pressure you have during normal run conditions? I'd drop the oil pan and look at the pickup, they've been known to fail but they also generally take out the bottom end when they do. What about the oil lines to the turbo? Were they replaced? Didn't check the oil pressure, but the lines were replaced. I'm replacing all of crush washers, any idea where I can find a diagram or something for the order they go on? Link to comment Share on other sites More sharing options...
05redLGT Posted December 14, 2016 Author Share Posted December 14, 2016 Any idea what sort of oil pressure you have during normal run conditions? I'd drop the oil pan and look at the pickup, they've been known to fail but they also generally take out the bottom end when they do. What about the oil lines to the turbo? Were they replaced? If its your second turbo in two years there is a problem. Turbos just don't die randomly as much as the hive mind would like to tell you there is a cause and effect for all parts failures. Could be - Poor oil change intervals - Poor oil quality - Low oil levels - Clogged banjo bolt filters I want to believe! But you your points, 3k intervals, mobil1 syn oil, always checked level and took out one of the filters it wasn't that clogged... I need to inspect the conviniently placed filter behind the drivers side cam cover Link to comment Share on other sites More sharing options...
Holla Posted December 14, 2016 Share Posted December 14, 2016 Well, sounds like you may already have your answer. You definitely need to remove that filter and see what it looks like. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 14, 2016 Share Posted December 14, 2016 If you decide to keep the car for a long time, you should seriously invest in the btssm app. You will be able to view live a bunch of parameters including the VVT L/R angles. These two variables are directly related to the oil control valves. They should always be in sync. If not, you know something is wrong with either one of them or the oil flow. I view them at all times when I drive, cause I know if one of them fails, the turbo could be next. Link to comment Share on other sites More sharing options...
xt2005bonbon Posted December 14, 2016 Share Posted December 14, 2016 Here is a screenshot of my current btssm set up. Link to comment Share on other sites More sharing options...
Max Capacity Posted December 14, 2016 Share Posted December 14, 2016 I want to believe! But you your points, 3k intervals, mobil1 syn oil, always checked level and took out one of the filters it wasn't that clogged... I need to inspect the conviniently placed filter behind the drivers side cam cover There's the first issue, Mobil 1, please tell us your not using 5w-30 Mobil 1. The vf40 is a replaceable turbo. Most of us upgrade to a vf52. Mine with over 92,000 miles has zero shaft play. I use Amsoil European 5w-40 Classic full SAPS with 7000 mile oil changes, using their filters. There are very few oils we recommend, Mobil 1 is on the top of the do not use list. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
JustCallMeNick Posted December 14, 2016 Share Posted December 14, 2016 Good luck! I'm at 131k and not looking forward to replacing the whole engine at 200k when it blows up as the long time owners seem to report on here. It sucks to have something like that happen on such an expensive and capable vehicle. That being said, I'm knowingly planning to push it to stage 3-3.5 so obviously I'm not THAT broken up about the longevity. I agree though that even though turbos do eventually fail, they should last much longer than 12k miles. If you get another turbo, get a blown one and have it rebuilt by mike at tuning alliance. It'll be MUCH more trustworthy. Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 14, 2016 Share Posted December 14, 2016 Turbos only fail due to something the owner did. In this case, the Mobil 1 coupled with not removing the banjo filter is basically a kiss of death. There is nothing inherently wrong with the VF40 that regular maintenance, good oil and filters, and NO banjo filter can't fix. I see them all the time with bad journal bearings and I can tell by how the turbo smells that the owner was using Mobil 1. I fix the oiling issues when I build them but even then, no maintenance equals POOF. Link to comment Share on other sites More sharing options...
Gigs Posted December 15, 2016 Share Posted December 15, 2016 Yeah 5w30 mobil 1 is rather thin for a 5w30 Link to comment Share on other sites More sharing options...
rmoore5 Posted December 15, 2016 Share Posted December 15, 2016 I have 288k on mobil 1 exclusively The last Blackstone was a glowing testament. Proper OCI is the key, and not shutting the turbo off when it is red hot I believe. Link to comment Share on other sites More sharing options...
05redLGT Posted December 15, 2016 Author Share Posted December 15, 2016 Maintenance has been on point every 3k for oil and trans and diff fluids... has a receipt for every single service, it's 2 inch thick folder... previous owner was old and ocd, I thought I got a freaking jewel.. timing belt and pump receipts, gaskets, clutch, new tires, etc... I mean clean... so that was 800 miles ago... oil was clean and topped off, smelled a bit like coolant everytime you rip a lil... lower turbo coolant hose..rly? And that's it Link to comment Share on other sites More sharing options...
05redLGT Posted December 15, 2016 Author Share Posted December 15, 2016 sooo, does anyone know the order of the crush washers that go on the lines on the turbo?.. Link to comment Share on other sites More sharing options...
magnusonsubie Posted December 15, 2016 Share Posted December 15, 2016 sooo, does anyone know the order of the crush washers that go on the lines on the turbo?.. Seriously? they are crush washers its not rocket science. One on either side of each banjo fitting. Now your turbo failure issue is not difficult and has been covered on this site and linked to the information you need. If when your first turbo went there was bearing material still in oil passages, the pan, where ever it was only a matter of time before it took out the next turbo. And further on its only a matter of time till all these turbos take out your entire engine. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
Max Capacity Posted December 15, 2016 Share Posted December 15, 2016 Any auto parts store will have a selection of crush washers, or the dealer will have them too. Yea, I'll have to agree with JmP, HAMMERDOWN has 300,000 miles on his vf40. But he also has a killer oil system. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Rhitter Posted December 15, 2016 Share Posted December 15, 2016 Yea, I'll have to agree with JmP, HAMMERDOWN has 300,000 miles on his vf40. But he also has a killer oil system. With his two filter oil system, he cheats My OBXT build Link to comment Share on other sites More sharing options...
HAMMER DOWN Posted December 15, 2016 Share Posted December 15, 2016 With his two filter oil system, he cheats No cheating here , just paying a little forward. So I don't have to pay a lot, later on. FYI. It did have a signal oil filter in the stock location for the 1st 73k. Mileage:331487 Retired/Sold Link to comment Share on other sites More sharing options...
Dishwasher Posted December 16, 2016 Share Posted December 16, 2016 Strongly considering that two oil filter system Hammer Down, any regrets? Link to comment Share on other sites More sharing options...
