Dphil25gtwagon Posted December 14, 2016 Share Posted December 14, 2016 This is just a copy and paste from my build. Its starting to get serious so I started a new post. So here we go... ______________________________________________ 78000 mile update: Noise from underneath. Sounds like gearbox. [ame=http://www.youtube.com/watch?v=XDBIlwF-ZME]05 Subaru Legacy gt 5speed noise - YouTube[/ame] I removed the drive shaft and the joints seemed pretty notchy so i oreder a used shaft, and it felt identical. So I drove the car on the lift in FWD and still heard the noise. I then popped the plug out of the trans and found this. [ame=http://www.youtube.com/watch?v=oLsz675g-Ec]5mt at 78k miles - YouTube[/ame] Sadness ensues. PS: Sorry I havent figured out how to embed yet __________________________________________________ Ok so I cracked the damn thing open and right were i heard the noise, i found this... http://i.imgur.com/belFCIj.jpg http://i.imgur.com/GLFRTnh.jpg http://i.imgur.com/GLFRTnh.jpg http://i.imgur.com/BA3RFa8.jpg So can anyone tell me if I should keep going or is this the problem... Link to comment Share on other sites More sharing options...
magnusonsubie Posted December 14, 2016 Share Posted December 14, 2016 Following. But it appears that you blew your center diff! 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
tysparks81 Posted December 14, 2016 Share Posted December 14, 2016 yea doesn't look good, subscribed. #LGTSTi is still cheaper and nicer then an equal year wrxsti Follow my 2007 Spec B. Build here Link to comment Share on other sites More sharing options...
Dphil25gtwagon Posted December 14, 2016 Author Share Posted December 14, 2016 http://i.imgur.com/zoKl3uy.jpg So this bearing is making a lot of noise. Maybe the main noise thats in the video. you can see some wear on this race as well. http://i.imgur.com/MqeaJbR.jpghttp://i.imgur.com/eIGLf70.jpg I think at this point it was a center diff failiure. Ive read enough similar stories that have matched my symptoms. At this point I'm just going to replace what is damaged and cross my fingers the thing will hold on until i can find a 6Mt setup. Ill call around later and find out some prices. Link to comment Share on other sites More sharing options...
GEE-OTTO Posted December 15, 2016 Share Posted December 15, 2016 If your shifting was always smooth you are likely correct with your choice to replace the center diff and button it back up. Link to comment Share on other sites More sharing options...
whitetiger Posted December 15, 2016 Share Posted December 15, 2016 time to put in a ppg center diff. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 15, 2016 Moderators Share Posted December 15, 2016 Embedded the videos for you. All you need to do is remove the 's' from the "https" and it will embed. "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
Dphil25gtwagon Posted January 8, 2017 Author Share Posted January 8, 2017 Update on the center diff. I have a spare 5mt from the gc8 project I'm working on atm which happens to have the same center diff as the lgt. So I may try to swap it out once I get some of the races and bearings in. Ill be ordering a clutch soon as well. Lets here some stories about what and what not to get. I'm stage 2 atm, but that could change at any moment lol. Id like to keep pedal feel as close to stock as i can, but a little more push can be expected. Definitely do not want a noisy clutch. Im looking at the competition clutch stage 2 kit. Any others I should consider? Link to comment Share on other sites More sharing options...
magnusonsubie Posted January 8, 2017 Share Posted January 8, 2017 Competition clutch stage 2 kit has a significantly heavier clutch feel than stock. I hate mine in traffic. But other than that it chatters a bit in first on hill start engagements. It's a good clutch but definitely heavier pedal feel and a bit of noise. 2005 Vader Wagon Material Tests on Ringland Failure Piston I should have held off and purchased a wagon instead of the spec.B Link to comment Share on other sites More sharing options...
RumbleRumble Posted January 8, 2017 Share Posted January 8, 2017 what the hell is that green shit. Link to comment Share on other sites More sharing options...
Max Capacity Posted January 8, 2017 Share Posted January 8, 2017 FWIW, my center diff did the same thing. New Viscous coupling and all new bearings. This happened Dec 2015. I have a post here some where about it. My fluid was gray color, it was the last of my Extra-S. For a clutch, get a Spec 2+, I love mine, it has a light pedal like the stock clutch in my Spec B. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
