strikerusn Posted December 13, 2016 Share Posted December 13, 2016 It's been a hectic month. Car was making a weird noise at first and that weird noise become into a knock. So currently the car will be sitting till I decide if I want to continue to work on it. Does anyone know about how much a head costes plus labor? Sent from my LG-H830 using Tapatalk Link to comment Share on other sites More sharing options...
Dishwasher Posted December 15, 2016 Share Posted December 15, 2016 4-$500 for machining Link to comment Share on other sites More sharing options...
strikerusn Posted December 16, 2016 Author Share Posted December 16, 2016 4-$500 for machining So that's basically rebuilding the head? Sent from my LG-H830 using Tapatalk Link to comment Share on other sites More sharing options...
swisscheese Posted December 22, 2016 Share Posted December 22, 2016 Go to "12 yr. old timing belt" on first page of new posts. Link to comment Share on other sites More sharing options...
ehsnils Posted December 22, 2016 Share Posted December 22, 2016 So that's basically rebuilding the head? Depends on what needs to be done and how much you can do yourself. Minimum for a head is replacing seals, re-seating valves and checking/adjusting clearances. Step up is to also replacing the valve guides, which may or may not be needed. How far you need to go depends on what you discover when you have removed the head and disassembled it. Link to comment Share on other sites More sharing options...
Dishwasher Posted December 22, 2016 Share Posted December 22, 2016 Any check engine lights or anything else other than the knocking noise? Is your car using oil? Link to comment Share on other sites More sharing options...
