Gigs 2006 Legacy GT Limited Wagon and STi Wagon
I basically have a habit of ruining my daily drivers so I will refrain from doing it again with this car but the goal is a comfortable daily driver that is reliable so most of the mods will be for reliability sake.
You can find my older build thread for my wrx here as well
http://forums.nasioc.com/forums/showthread.php?t=2712350
Youtube - https://www.youtube.com/channel/UCR9dFmgscOogL5zOydUWXwA/feed
Instagram - https://instagram.com/jn_garage/
Website - https://jngarage.com/
Spring 2017 Plans
VF52 , TMIC , Safe tune and Spec B Billstein struts
Engine
Stock
Transmission
Stock 5at
Suspension
Stock , But suspect it was replaced
Interior
VicTsing FM Transmitter, Bluetooth FM Transmitter Radio Adapter Car Kit
Exterior
Stock
Wheels / Tire
Winter - Stock wheels with 215/45/R17 Hankook I Cept Evo 2 snow tires
Summer - Looking for 17x8 or 17x7.5 Rays TE37 / CE28n with 225/45/R17 Continental DW
http://i.imgur.com/GHKiogi.jpg
http://i.imgur.com/icyRjqf.jpg
http://i.imgur.com/ywAZjxC.jpg
2003 Wrx wagon
2003 Subaru Wrx Wagon
Exterior modifications
Sedan widebody conversion
Prodrive bumper
Engine
S204 EJ207
3 Port EBCS
Tomikoa Downpipe
Greddy TI-C catback
Koyo Radiator
Samco hose kit
Transmission and Driveline
Group N Bushings
Exedy twin plate clutch
Version 7 R180 suretrac LSD
Version 7 Type RA STi Transmission
Ratios
3.636
2.375
1.761
1.346
1.062
0.842
Brakes and Suspension
Version 7 STi Brembos
Brembo Rotors
Project Mu NS400 / HC800 pads
Prova replica brake ducts
21mm Front and Rear STi S204/ RA-R Sway bars
STi Pink trailing arms
Version 7 STi lateral links
Wheels and Tire
Mach V Awesome 17x9 +42
245/40/R17 Hankook RS3
http://i.imgur.com/MOJN4rH.jpg
http://i.imgur.com/2QKRxwW.jpg
http://i.imgur.com/Emf6XCu.jpg
  • Replies 204
  • Created
  • Last Reply
Top Posters In This Topic
Noticed the radiator is to seep a little bit from the top and I have a tiny coolant leak from the top turbo coolant line. Radiator can wait till spring but I will likely replace both oil and coolant lines when I go to do the banjo bolt removal.
I also picked up some 0w40 Castrol Syntehtic and 5w30 Castrol Synthetic for dirt cheap on amazon. Probably will run the 5w30 now during winter and the 0w40 during summer but I may do the 0w40 in winter once I get an oil test back from the 5w30.
Its a wonderful 14 degrees today in Michigan , This is our gass guzzler vip parking area.
http://i.imgur.com/bUXDA3Z.jpg
Very nice. Both look great. Im in Kalamazoo area so I know the beauty of the wonderful weather
Its awful , I should be out at Gingerman a few times next year when its warm out as I have a lot of seat time to catch up on.
2017 goals are track days bro
Maybe I should finish my 5x114 swap too and get some Feal 441 coilovers
I have STi pink trailing arms , lateral links and more suspension bushings waiting for spring along with a 2004 Sti steering rack.
http://i.imgur.com/sewElLB.jpg
http://i.imgur.com/ucAw20I.jpg
  • 2 weeks later...
Well the Lesbowagon started to pee coolant all over earlier this week but I had saw this coming and ordered a new oem radiator. I then limped it on over to a local dealer and had a friend swap the new one in along with some other service items.
Bugeye got a battery tender too yayyyy
136,000 miles
New spark plugs
New oem radiator
New O2 sensor
New Battery
Also fixed a few leaky hoses and such that were annoying.
Old spark plugs looked like they had some serious miles on them , O2 sensor was not really needed but it won't hurt and its one less thing to worry about. Car should be set for a long time now.
http://i.imgur.com/fZMTj50.jpg
http://i.imgur.com/wFpGiYR.jpg
http://i.imgur.com/k6bZoJF.jpg
http://i.imgur.com/VgRqsdE.jpg
http://i.imgur.com/ZYEoWJc.jpg
Well I picked up some deals during the holiday season for both cars
Legacy GT wagon is getting some Spec B Billsteins with STI springs , 225/45/R17 Continental DW tires mounted on 17x7.5 +48 TE37s.
http://i.imgur.com/g2PPhLi.jpg
Bugeye is getting a 5x114 swap , suspension refresh , Feal 441 Coilovers and 18x9 +35 Enkei RCT4.
Now I have to just wait for the other two 18x9 +35 RCT4 to show up as I have had two in storage for over a year now. I also have to stalk feal for more information on their electronic dampening system and hope that they have a tax season sale !
I am leaning towards this color like I did my last set that I was supposed to run and I kinda want to do it for the TE37s as well. All Gold everything or perhaps should I do the TE37s in a nice gloss black ?
http://i.imgur.com/2prrVnI.jpg
Ordered timing parts and suspension bushings for the Bugeye today to come along with the Legacy suspension.
Just need a few more items then I will have all the parts ready for spring service , I still am debating doing a new R180 LSD as well. There is a local track group that is renting out Mid Ohio on August 28th which happens to fall right on my birthday weekend so I signed up to treat myself to driving a FIA grade 2 track and a nice long weekend !
http://i.imgur.com/boDniLX.jpg
Very cool car! What's the difference between the limited wagon and the regular GT?
I think there was only a difference for 2005 , This car has almost every option that was offered though.
Subbed! cars look great btw!
Thanks !
So far this is the list for spring , I already have most of this laying around on the shelf.
- Replace S204 oil cooler lines with new oem lines
- Group N or Superpro bushings for everything
- STi Pink lateral links and trailing arms
- 5x114 Hub swap
- Feal 441 Coilovers 9k/8k spring rates
- STi or Cusco clutch type R180
- 18x9 +35 Enkei RCT4 with daily / rain tires
- 2015 Sti steering rack
- Spec C power steering pump
- STi oem short shifter
- Spec C Version 8 seats
- Retune with Id1000cc injectors and probably E85
"For 2006, the regular GT was dropped" (source: Wikipedia)
As Gigs said, Limited was offered as a special trim level for 2005.
Nice looking cars! Keep the pics coming. :)
Edited by JustCallMeNick
Damn near same setup I have, except I have 55 profile DWS06. You're gonna absolutely love the handling for a daily driver.
MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance
Everyone knows what I taste like.
Yeah that is the idea , it floats over things on the highway and does not feel as planted.
I think a rear sway bar is in order too.
Doing some more research on the EJ20Y swap I want to do on this car and after talking with people who have done it and reading every post I can find I have come to this basic concept.
You will need to wire in AVCS and OCV lines for the exhaust AVCS then repin them on the JDM ecu which is identical to the usdm ecu except it has wiring going to pins for the exhaust side avcs. Then you will need the jdm ecu married to your immobilizer at a dealership or have someone with the correct skills do it for you. Alternatively people have had their usdm immobilizer chip soldered onto the jdm ecu as well but that requires a special set of skills.
When comparing say a 2005 JDM Legacy 2.0GT to a 2005 USDM Legacy GT oem tune the tables are all the same with the addition of exhaust AVCS tables from what I am seeing so far. Obviously the data in the tables is very different as you are comparing two very different engines that essentially run on the same type of ECU.
Things that I still am not 100% on would be the automatic TCU interaction with the JDM rom but the tables seem to be similar. Also sourcing specific sensors / parts for the exhaust side avcs might end up being a pain in the ass but should be able to be imported from Japanparts as judging by bugeye parts the BP/BL Legacy still has another 3-5 years of parts service from Japanese dealerships.
Did the whole Detroit auto show today.Legacy got premium vip protected parking spot.
http://i.imgur.com/b3xl5hM.jpg
Man the 2018 STi is kinda sad , The brake upgrade is great but the front end is hard to look at and the interior is still pretty lackluster for a $35,000 - $40,000 car. There were some awesome race cars here too like the NSX , Ford GT and M6.
http://i.imgur.com/d5sd08H.jpg
http://i.imgur.com/lYCyFvq.jpg
http://i.imgur.com/Ihpl7Oe.jpg
http://i.imgur.com/MsHQGc8.jpg
http://i.imgur.com/VYuTVdp.jpg
http://i.imgur.com/JiLbPmy.jpg
http://i.imgur.com/YgcbAzy.jpg
http://i.imgur.com/bFs7SzI.jpg
Signed up for all three days so I will get a ton of seat time , car will consume gallons of fuel and it will be glorious. Also going to be running on 5x114 STi bbs for the track as they are dirt cheap and fit a 245 easily. Going to run the RCT4 if it rains and when driving around town.
Things to do before hand now
  • 5x114 Hub swap
  • Suspension refresh
  • R180 seals need replacing
  • Feal coilovers
  • complete fluid flush
  • Timing and misc services before tracking the car
  • Maybe E85 and Id1000s ?
Digging the build, man. Wondering what is a good price on low mileage spec b bilsteins with pinks? Shopping around for my own, a ballpark would help greatly.
Shipping and conversion rates made my head swim looking last night. Thanks.
I would say under $450 is a good deal , Shipping in general will be around $150-$200 from Japan usually.
Did a wheel drop Friday and filled the hell out of the legacy.
http://i.imgur.com/0UOsKOb.jpg
http://i.imgur.com/svhLvbG.jpg
RCT4 will be gold for sure
TE37s maybe a nice glossy black ?
http://i.imgur.com/52l8WlM.jpg
http://i.imgur.com/PiSArX9.jpg
http://i.imgur.com/VyXpIiL.jpg
