SpecBlitzed Posted December 5, 2016 Share Posted December 5, 2016 2008 subaru legacy SPEC B I few days ago my key fob completely stopped working. Figured was a ez fix change the battery and problem solved. Switched the new battery into both key fobs and same thing none of the button functions are working. I found a post on NASIOC for key fob keyless entry reprogram reflash. I preformed the reflash with no issues and still nothing is working. All door and windows are working from inside the car. The alarm is also working by locking the doors from inside the car and closing door. The horn beeps and lights flash telling me the alarm is armed. Iam thinking its the keyless entry module but can't track down a thread on location or part number to replace it. Could it be a fuse or something simple. Any advise on what to do would be great appreciated. Cheers and God bless. Link to comment Share on other sites More sharing options...
SpecBlitzed Posted December 6, 2016 Author Share Posted December 6, 2016 Bizzity Link to comment Share on other sites More sharing options...
Max Capacity Posted December 6, 2016 Share Posted December 6, 2016 Read the other two below, today about fob issues. Wow, 3 in one week and its only Tuesday... 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
SpecBlitzed Posted December 20, 2016 Author Share Posted December 20, 2016 Took it to the dealer spend $77 for a keyless entry diagnostic. Both the key fobs are junk. Beware before you take it to the dealer. Replaced the fob problem solved Link to comment Share on other sites More sharing options...
