Le Gabbys Posted December 5, 2016 Share Posted December 5, 2016 So I've read the suspension faq a few times and I'm wondering has anyone ever bought kyb oems and and used them with forester springs? I really want to get a couple more inches so I can get some all terrains for the dirt but I don't want to buy struts I just bought some within the year. Sent from my LG-H631 using Tapatalk Link to comment Share on other sites More sharing options...
Stevh0 Posted December 5, 2016 Share Posted December 5, 2016 Why not just go with strut spacers? Link to comment Share on other sites More sharing options...
scoobydo2.0 Posted December 6, 2016 Share Posted December 6, 2016 So I've read the suspension faq a few times and I'm wondering has anyone ever bought kyb oems and and used them with forester springs? I really want to get a couple more inches so I can get some all terrains for the dirt but I don't want to buy struts I just bought some within the year. Sent from my LG-H631 using Tapatalk When you say OEM KYB struts are you referring to Legacy L, Outback, or Forester? They all have different part numbers but they are all within 1/2" of each other in length so you don't lose any height there. Get a set of used Outback springs or these - http://get-primitive.com/springs/135-king-raised-springs-1995-1999-outback.html for a badass setup. I've made spacers using a high density plastic cutting board before, its really easy, just use the strut mount as a template and cut it out with a jigsaw.. Voila. It cost way less than buying them Link to comment Share on other sites More sharing options...
Brighton96 Posted December 6, 2016 Share Posted December 6, 2016 When you say OEM KYB struts are you referring to Legacy L, Outback, or Forester? They all have different part numbers but they are all within 1/2" of each other in length so you don't lose any height there. Get a set of used Outback springs or these - http://get-primitive.com/springs/135-king-raised-springs-1995-1999-outback.html for a badass setup. I've made spacers using a high density plastic cutting board before, its really easy, just use the strut mount as a template and cut it out with a jigsaw.. Voila. It cost way less than buying them I beg to differ on the strut length, well assuming I know what the PO put on my car, the struts on the rear of my car were I THINK from a legacy and the Outback struts I replaced it with were nearly 2in longer, and by longer I mean the body of the strut was clearly longer and from that, I gained about 1.5 in of rear ground clearance. Link to comment Share on other sites More sharing options...
wtdash Posted December 6, 2016 Share Posted December 6, 2016 don't forget about the height of the 'spring perch' on the stock/kyb struts. You might fit taller springs, but taller tires may not fit under the perches. - this is for the '98 L in your Sig/Avatar. Td Link to comment Share on other sites More sharing options...
Le Gabbys Posted December 10, 2016 Author Share Posted December 10, 2016 Why not just go with strut spacers? I've never really liked the idea of spacers I feel like they would be potentially damaging to my suspension, like wheel spacers can cause. Sent from my LG-H631 using Tapatalk Link to comment Share on other sites More sharing options...
Le Gabbys Posted December 10, 2016 Author Share Posted December 10, 2016 When you say OEM KYB struts are you referring to Legacy L, Outback, or Forester? They all have different part numbers but they are all within 1/2" of each other in length so you don't lose any height there. Get a set of used Outback springs or these - http://get-primitive.com/springs/135-king-raised-springs-1995-1999-outback.html for a badass setup. I've made spacers using a high density plastic cutting board before, its really easy, just use the strut mount as a template and cut it out with a jigsaw.. Voila. It cost way less than buying them Thanks for the info I'm gonna have to think about my options now. Sent from my LG-H631 using Tapatalk Link to comment Share on other sites More sharing options...
Setnev Posted December 10, 2016 Share Posted December 10, 2016 If you're wanting to lift it right, I would check out SubieLiftOZ. They quoted me $490 shipped from Australia for 4.5 inch lift kit. It comes with the following things: - Front & Rear 4.5" strut spacers - Rear trailing arm spacers - Lower control arm spacers - Engine, transmission, & differential spacers - Differential outrigger spacers - Center bearing spacers - Extended steering knuckle - Top Radiator hose extension - Replacement fuel and charcoal canister hoses - Handbrake cable extensions - Air Box spacer - Rear camber bolts. I think for $490 for that whole kit is definitely worth it. Link to comment Share on other sites More sharing options...
Le Gabbys Posted December 10, 2016 Author Share Posted December 10, 2016 I beg to differ on the strut length, well assuming I know what the PO put on my car, the struts on the rear of my car were I THINK from a legacy and the Outback struts I replaced it with were nearly 2in longer, and by longer I mean the body of the strut was clearly longer and from that, I gained about 1.5 in of rear ground clearance. That's good to know I'm trying not to dump a lot of money into this so if I can squeeze out more height with the right combo then that would be great Sent from my LG-H631 using Tapatalk Link to comment Share on other sites More sharing options...
Le Gabbys Posted December 10, 2016 Author Share Posted December 10, 2016 don't forget about the height of the 'spring perch' on the stock/kyb struts. You might fit taller springs, but taller tires may not fit under the perches. - this is for the '98 L in your Sig/Avatar. Td Yeah this is going to be for that L wagon,though it looks different now. And your right about that perch thing I don't know why I didn't remember that I'm gonna have to take measurements of something. Sent from my LG-H631 using Tapatalk Link to comment Share on other sites More sharing options...
Le Gabbys Posted December 10, 2016 Author Share Posted December 10, 2016 By the way thanks for all the feedback, you guys rock. Sent from my LG-H631 using Tapatalk Link to comment Share on other sites More sharing options...
Kantdrive Posted December 22, 2016 Share Posted December 22, 2016 Kinda such in the same place as le gabbys but with a 99 sus just wondering does this info apply to my car Link to comment Share on other sites More sharing options...
