Scotty Posted December 4, 2016 Share Posted December 4, 2016 I maybe giving my car to a relative in Portland. My 05 LGT has a BNR turbo, catless uppipe, and a tune. From what I can find on Google, Oregon does a OBD 2 check and that's it. Is that correct? Do they do any inspections to see if all the cats are present? Thanks. Link to comment Share on other sites More sharing options...
shralp Posted December 4, 2016 Share Posted December 4, 2016 Yup OBD with no visual. As long as you have a cat in the DP and the car is running ok you'll be good. Link to comment Share on other sites More sharing options...
nads Posted December 18, 2016 Share Posted December 18, 2016 They do a scan that can tell how long until the last clear or reset on the ecu, so if you flashing tunes you will need to drive about 500 miles to pass that. And they sometimes will do a visual inspection, they have on my truck every time. They will also fail you for noise. Link to comment Share on other sites More sharing options...
Sgt.Gator Posted December 22, 2016 Share Posted December 22, 2016 Tell your relative to move to Bend, no smog checks here. Nothing like a race track to find the weak points in man and machine. "Good Judgement comes from Experience. Experience comes from Bad Judgement" Link to comment Share on other sites More sharing options...
