retinasurgeon Posted December 2, 2016 Share Posted December 2, 2016 Hi, planning to have my power steering pump changed. The parts available I see available online are 33430AJ023 which is for the Subaru Legacy 2.5GT 6 spd manual available in the US. However, the Legacy 2010 released in the Philippines is the 5AT version at the part no is 33430AJ011. I would like to ask if there is a difference between the 2 since both use the same engines (different transmission though). I know the j023 are made in the US and the J011 are made in Japan (from the info I have gathered) Thank you all for your outputs. Link to comment Share on other sites More sharing options...
ssulb Posted December 3, 2016 Share Posted December 3, 2016 Maybe the way the hoses are connected is different. I know in like for example the EJ207 JDM engines, they used a different pump than the EJ205 USDM. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
foxrider28 Posted December 4, 2016 Share Posted December 4, 2016 Keep in mind some JDM/EDM use electronic power steering and USDM is belt driven only. Link to comment Share on other sites More sharing options...
