Starting a 2009 in cold weather
Hi, I have a 2.5i with around 90,000 miles but in good driving condition. I recently moved to Anchorage, AK from WV. Prior to the move I had the oil changed to synthetic as I had read it performs better in very cold weather.
I keep the car in my garage but at work there is only outdoor parking. Last couple nights it has been 0 - 10 degrees F. When I start it in the cold after work it turns over fine but makes a loud, high-pitched rattle for a split second until I turn the key back; sounds fine after that. Never noticed this in warmer weather and sounds like it would be damaging. Is this maybe from the oil thickening up?
Thanks.
Does the noise stay on if you don't turn the key back?
I suspect what you're describing is the starter hanging. It surprised me too after I bought my 2009 Legacy. I guess they have to be taken apart and greased or something. I haven't gotten around to that.
http://legacygt.com/forums/showthread.php/scraping-sound-during-cold-engine-starti-149695.html
Read that link above, its easier then it sounds to take the starter apart and grease it.
I believe there are some good pictures in there.
Scratch that, here's the link I thought he posted. I didn't read the link in post 2.
http://legacygt.com/forums/showthread.php/diy-starter-repair-remove-disassemble-grease-reinstall-w-pics-218329.html
Engine Build - Click Here
