Bdoublet7 Posted November 4, 2016 Share Posted November 4, 2016 Just bought a 2013 Legacy Limited with 16k miles ha! Got it home to realize there was some condensation on the inside of both headlights, I'm assuming this isn't normal? Any fixes? Link to comment Share on other sites More sharing options...
LatentWagen Posted November 4, 2016 Share Posted November 4, 2016 It is normal. Could be that the seal on the headlight itself has broken or failed, allowing water to leak in. Or it could be that the gasket on the bulb cap is misaligned, dirty, or kinked. Twist the cap off the back and let the interior lamp housing dry, fully. Then check the rubber gasket before carefully re-installing. Sometimes I put a little mineral oil or other lube on the rubber to make sure that it doesn't get bunched up. If after reinstalling everything, the condensation still comes back, you may need to reseal the lamp. High-temp silicone works well. LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
FLlegacy Posted November 4, 2016 Share Posted November 4, 2016 I am fairly sure the lights are not sealed air tight. Seeing as how I have wasps in mine. So somehow water got into the vents or ports in your lights. To get it out you will probably need to take the lights out at the very least, or take them apart worst case. It would be a great time to mod them! Sent from my SAMSUNG-SGH-I337 using Tapatalk Link to comment Share on other sites More sharing options...
LatentWagen Posted November 4, 2016 Share Posted November 4, 2016 I am fairly sure the lights are not sealed air tight. Seeing as how I have wasps in mine. So somehow water got into the vents or ports in your lights. To get it out you will probably need to take the lights out at the very least, or take them apart worst case. It would be a great time to mod them! Sent from my SAMSUNG-SGH-I337 using Tapatalk There should be drain vents, but the interior won't always dry faster than the water piles up. Opening up the back of the lamp usually does the trick. It all depends how much water is getting in, and where. On my Saabaru there was a small break in the seal on top, but it was right where the hood line was, so water was channeled in whenever it rained. The headlight looked like a fishbowl LW's spec. B / YT / IG Link to comment Share on other sites More sharing options...
Bdoublet7 Posted November 4, 2016 Author Share Posted November 4, 2016 I'll keep that in mind, it's under some gold warranty, I'll at least try and get them to do something about it. Have people modded these headlights?? Link to comment Share on other sites More sharing options...
fedaykin Posted November 7, 2016 Share Posted November 7, 2016 Yep, fairly easy to take apart (with a heat gun and some patience). Use "rubber butyl glue", can get a roll of it for cheap on ebay etc. While you have it apart, might as well throw some HID projectors in there (and paint the surrounds black) Link to comment Share on other sites More sharing options...
Bdoublet7 Posted November 7, 2016 Author Share Posted November 7, 2016 I started some research after you said something. I have a limited 13, most of my housings are black already, and their is a projector in there. Can I just put an HID bulb in and use the factory projector? And since I have your attention, instead of opening a new thread, my passenger side door lock switches don't illuminate red like the rest of them, is it supposed to? Or does it remain unlit? Link to comment Share on other sites More sharing options...
fedaykin Posted November 9, 2016 Share Posted November 9, 2016 You could, but you're still putting a rebased bulb in a halogen projector. Or you can grab "black series" projectors (or another projector of choice, like Mini D2S 4.0) from the retrofit source and D2S bulb like Philips 85122 + Denso slim (or DLT F3) ballasts and have a much better output. Link to comment Share on other sites More sharing options...
