Ajfrassetto Posted October 31, 2016 Share Posted October 31, 2016 So im running into an issue. Tore my turbo up, and figured id do rods pistons. Turned into going all out. 99.5 dimamond pistons, manley turbo tuff rods, sti heat treated crank, top feed injectors, iag aos and put a bnr 16g turbo on it. All said and done, car made 273 271. Ok, it was 100 degrees outside, plus was the 10th pull on the motor. Feels good on the street, take it to the track friday, air is great. Good da, and its 48 degrees outside. Car goes 13.94 @ 97mph. 1.81 60'.....wtf, back it up with exactly same time. Issue i see is, the turbo is not making power until 4k rpm... on a 16g. Anyone ever seen that or know what may cause the turbo to spool up so late? Link to comment Share on other sites More sharing options...
Nightmaresmk Posted November 2, 2016 Share Posted November 2, 2016 bad wastegate Link to comment Share on other sites More sharing options...
jersdunz Posted November 17, 2016 Share Posted November 17, 2016 Well, did you figure it out? Curious.. Link to comment Share on other sites More sharing options...
Mike07LGT Posted December 16, 2016 Share Posted December 16, 2016 Could be the tune... Not to mention many issues with that turbo here on the forums so its not recommended. A VF52 would be a more reliable option for bolt on 03 WRB WRX (RIP) 04 JBP STI (sold) 07 DGM Legacy GT (RIP) 12 OBP STI (DD) Link to comment Share on other sites More sharing options...
Th3Franz Posted December 21, 2016 Share Posted December 21, 2016 check for boost leaks -Franz The end of a Legacy http://www.youtube.com/th3franz Link to comment Share on other sites More sharing options...
