Rooster22 Posted October 30, 2016 Share Posted October 30, 2016 I drained the fluid and installed a new filter in a 1991 Subaru Legacy. When I add new fluid it won't drain into the pan it just backs up the dip stick. When I changed the filter, to get it off, I had to pull out one end of some tube that had it pinned in. More fluid came draining out. I put the new filter in, put the end of the tube back in and then ran into the aforementioned problem. Is it some kind of vapor lock? I read something about bleeding air. Never heard of it, and no idea how to do it. What am I doing wrong? Sent from my Z793C using Tapatalk Link to comment Share on other sites More sharing options...
Rooster22 Posted October 30, 2016 Author Share Posted October 30, 2016 Transmission fluid Sent from my Z793C using Tapatalk Link to comment Share on other sites More sharing options...
Sarang Posted October 30, 2016 Share Posted October 30, 2016 This is the 2010-14 section, try asking over here: http://legacygt.com/forums/forumdisplay.php/first-generation-legacy-1989-1993-94.html Link to comment Share on other sites More sharing options...
Rooster22 Posted November 1, 2016 Author Share Posted November 1, 2016 OK, thank you. Don't really know how this works. Link to comment Share on other sites More sharing options...
GTEASER Posted November 1, 2016 Share Posted November 1, 2016 OK, thank you. Don't really know how this works. Just look at the main subforum menu. It will make sense. Moved to 1st Gen section. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
