DIY: Dimming mirror install 6th gen
This is a walk through with pictures of how to install auto dimming mirror with approach light and blind spot. This also applies to auto dimming mirror with approach light and NO blind spot.
In order for this to work, you MUST have the auto dimming rear view mirror. That works as the master, and the side mirrors the slaves.
Auto Dimming Mirror with Approach Light / Blind Spot:
P/N: J201SAL102
Purchase: http://subaruonlineparts.com/subaru-legacy-auto-dimming-mirror-with-approach-light-blind-spot-p-3647.html
Auto Dimming mirror with approach light:
P/N: J201SAL002
Purchase: http://subaruonlineparts.com/subaru-legacy-auto-dimming-mirror-with-approach-light-p-3646.html
There is a .PDF instruction form on the website, as well as attached below. This will mirror that, with tips learned along the way.
From start to finish, this took me 40 minutes, and that was with taking pictures every two seconds. Someone could knock this out in 20 minutes easy.
Tools required:
10mm wrench
dash removal tool/flat head screwdriver
needle nose pliers
microfiber cloth
flashlight
Let's get to it! Here's what the kit includes:
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_144649_zpswrecexym.jpg
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_144756_zpsztjxxd0k.jpg
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_144803_zpsis5hu5si.jpg
Step 1: Disconnect the battery. Both sides use a 10mm socket.
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_151158_zpsycjgyibi.jpg
Step 2: Use the dash removal tool or flat head screwdriver to pry out the old mirror. Pry straight back (a decent bit of force is necessary).
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_151300_zpsxqwuq71r.jpg
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_151340_zpsegm9567a.jpg
Step 3: Pull down on the mirror. The mirror will release completely.
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_151404_zpsp71visfb.jpg
Step 4: Unplug the wires. I found it easiest to release the wires from the little holders. For the heated mirror elements, they were on there tight. BE CAREFUL with these. DON'T pull directly on the wire. I used needle nose pliers and gently got them off with patience.
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_151507_zpsmp6f6lhk.jpg
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_151627_zpshnsqkkj3.jpg
New mirror VS old mirror:
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_151703_zpsourvsn5h.jpg
Step 5: Locate the wiring harness. It was very difficult to find at first as it blends it very well. It's wrapped in this sticky foam, and stuck to the back of the housing. Don't worry, it's back there. The needle nose pliers also came in handy here.
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_151802_zpst1sdrval.jpg
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_152143_zpsisgfoexz.jpg
Step 6: Unwrap the foam from the connectors.
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_152338_zpsh1wqh2yx.jpg
Step 7: Remove the prearranged connectors.
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_152426_zpsonmg1orw.jpg
Step 8: Apply grease into this random hole, or as Subaru calls it, the "outboard friction dampener". I found it was easiest to cut a corner of the grease off and squeeze it in there (just a little).
Before:
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_152554_zpsm3sftm6f.jpg
After:
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_152645_zps8sfc9ssx.jpg
Step 9: Install friction dampener spring into the OUTBOARD mirror holder. I just used the old mirror as reference.
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_152731_zpsvfriam4q.jpg
Step 10-13: Plug everything back in. Each connector is unique, so it's literally impossible to mess this up.
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_152846_zpsiave1xry.jpg
Make sure to put the wires in their holders.
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_152930_zpsqmp6gpqp.jpg
The heater terminals aren't specific to which one goes where. Just reconnect them.
Finished product:
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_153006_zpsyngaabga.jpg
J201SAL100.pdf
Edited by The Grey Goose
Step 14: Hook mirror into place. The green part hooks up into it, then the red snaps into place. I found it was easier to push the whole mirror outward so you can see it easier.
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_154226_zpshse3y07e.jpg
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_153028_zpse9kgdfcy.jpg
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_153033_zpsugghsip6.jpg
Repeat everything the same exact way for the passenger side.
Step 16: Reconnect the battery.
I used a microfiber cloth to wipe off all the fingerprints on the mirror from the install. Then you can also re-position the mirrors.
Now to test it! The instructions say to use something to block the light sensor on the rear, and turn the car on, but that did nothing for me. I ended up blocking the sensor and shining a flashlight into the front sensor.
http://i707.photobucket.com/albums/ww76/ticonderoga16/20161014_154639_zpsxnkygpxl.jpg
They're working! Congrats on the new mirrors!
  • 1 month later...
Wondering if I could do this on mine. I've got the auto dimming rearview mirror. Don't think there'd be a harness though for it. I've got the heated mirrors as well.
It'd be pretty easy to pop off your mirrors and check! Just make sure you really look to see if a harness is there because mine was hidden. Was it an option for your year?
  • 1 month later...
Do you guys know where the blind spot sensors are actually located (not the LED, the actual sensors)? Are they integrated in the mirrors or hidden somewhere on the sides of the car?
Looking in my service manual, the radars appear to be in the lower corners of the rear bumper.
I see. Just found this info as well:
"Rear Cross Traffic Alert (warns of vehicles approaching when you're backing out of a parking spot). The Subaru Rear Vehicle Detection (SRVD) system uses two radar units, each mounted underneath the sheet metal immediately below the rear taillights. To help avoid damage, the radar units are purposely mounted above the typical bumper impact line." - Cars101.com
All other information you'd want to know about the car that is available is on that page.
Also found this picture on cars101:
http://www.cars101.com/subaru/outback/outback16-blind-spot-detection2.jpg
Most likely the sensor is in that black box. Pretty large box.
And this one:
http://pictures.dealer.com/p/planetsubarusne/1186/1e52a013a439949ce0b79474cd945a7cx.jpg
I put that in here for the part number reference.
Edited by xt2005bonbon
  • 2 years later...
My Legacy Premium is 2015Y. My side mirrors are without blindspot and dimming. I think that if I want to install blindspot detection I need to by also the sensors/radars that are under the rear bumper. But do you know are there the wires to connect them to the system? Have got any experience with blindspot?
