RumbleRumble Posted October 5, 2016 Share Posted October 5, 2016 Have you tried cleaning your old mafs with maf cleaning? Link to comment Share on other sites More sharing options...
jimkelly1964 Posted October 5, 2016 Author Share Posted October 5, 2016 i will research this tomorrow. thanks for suggestion. sure wish i had both green plugs, not sure how i will reset ecu if i ever get all this sorted out? ebay maf was also missing its tang that holds plug from coming off. do i simply remove maf from car, spray wire, let dry, then reinstall? http://www.914world.com/bbs2/uploads/post-2460-1475712464.jpg Link to comment Share on other sites More sharing options...
wtdash Posted October 6, 2016 Share Posted October 6, 2016 Yes, I (but not everyone) recommend using dedicated MAF cleaner. If you use brake cleaner be careful as too strong a spray may damage the sensor. And disconnecting the NEGative battery cable overnight should clear the codes....the other green connector is probably still taped to another wire harness. Link to comment Share on other sites More sharing options...
jimkelly1964 Posted October 6, 2016 Author Share Posted October 6, 2016 dash wires - still looking http://www.914world.com/bbs2/uploads/post-2460-1475788967_thumb.jpg Link to comment Share on other sites More sharing options...
jimkelly1964 Posted October 7, 2016 Author Share Posted October 7, 2016 looking at my 2 pics, i saw something that looked like the plug i thought was missing. i have been upside down under my dash for probably 30 mins and thought i was barely toughing it and could see it. turned out my TCU (i think) is attached in that area with 2 nuts but 1 was missing. seems someone had it off before and when they put it back they buried the green plug behind it. bottom line is, i have 2 black and 2 green plugs, as it should be. http://www.surrealmirage.com/subaru/engine.html Link to comment Share on other sites More sharing options...
jimkelly1964 Posted October 8, 2016 Author Share Posted October 8, 2016 started my car about 20mins prior to starting my 3 hr drive. when I got in my car and begun my drive, my car stalled out probably 20 times +- in the first 2-3 miles, each time I put it in neutral and started it up, some of the times I was able to keep it from stalling with WILD GA PEDDLEING. I drove all highways at pretty steady speeds and may have felt 2 hickups but otherwise car drove smoothly. so far I tried a different cam pos sensor, a different maf, 16oz seafoam into iacv, new fuel filter. tomorrow I will pick up some more, trans fluid dex/merc, a fuel pressure guage, and a long skinny funnel, at advancedauto. binding in reverse is real bad but did not feel it driving forward to 3 hrs. i'd really like to put a fwd auto trans in it as this awd auto trans binding issue has gotten OLD. that that it is morning, and I am awake, I am thinking, wondering really, if this could be a symptom of iacv being dirty, I mean, my car was idleing happily befiore my drive, but under load it began to stall. I hope this car is able to do a few more round trips while I get another engine in my other car. http://www.914world.com/bbs2/uploads/post-2460-1463613852.jpg Link to comment Share on other sites More sharing options...
RumbleRumble Posted October 9, 2016 Share Posted October 9, 2016 Have you done plugs or wires? checked timing? get the fuel pressure regulator, could be vaper lock. if it is none of those I'm out of ideas. Link to comment Share on other sites More sharing options...
jimkelly1964 Posted October 10, 2016 Author Share Posted October 10, 2016 friday when i left work, my car stalled out 15-20 times in 2-3 miles BUT THEN it ran smoothly the rest of my trip. this morning i expected to have issues but it ran smooth all the way. so i'm thinking the new fuel filter and seafoam thru iacv, did the trick. now though my trans is shot. i can't drive it more than a few feet backwards before the binding is real bad. so for a while i am going to park it where i can pull out of spot in forward. while i get my other car running again. Link to comment Share on other sites More sharing options...
RumbleRumble Posted October 11, 2016 Share Posted October 11, 2016 Is it 5speed or auto Link to comment Share on other sites More sharing options...
jimkelly1964 Posted October 11, 2016 Author Share Posted October 11, 2016 my car is an auto but i am open to converting it to 5 spd. found a 5 spd 1991 semi near by for cheapish. my car is pretty rust free and engine runs smooth, i think it has many miles to go if i could get trans working reasonably well. Link to comment Share on other sites More sharing options...
jimkelly1964 Posted October 13, 2016 Author Share Posted October 13, 2016 well it seems that my car decided it was not fixed. and today after taking 3 150 mile trips, began to act up again, quite strongly. guess I'll pull some plugs to see what they look like. when I got car I was under the impression that it was well maintained but after seeing fuel filter, i'm thinking maybe it wasn't after all. anyone think it could be TPS? I have my doubts cause although I need to throttle throttle to keep car running, I get no feeling that there are dead spots on tps when doing so. I got a 0-60 psi fuel guage but am waiting on the barb gizmo to install it inline. as I do wonder if I have an INTERMITTANT fuel pump or fuel regulator issue. but maybe I need to do as previously suggested, remove and thoroughly clean my IACV. maybe the seafoam was just a short lived improvement. Link to comment Share on other sites More sharing options...
jimkelly1964 Posted October 14, 2016 Author Share Posted October 14, 2016 just removed iacv. busted the tee that is inline with the pcv valve. does have dirty in it but shaft seems to turn pretty easily. pulled pcv valve too and it seems to have decent action too. need to find that pvc line tee, any ideas? link to part numbers I need, hoses and conector http://www.surrealmirage.com/subaru/tech.html now to see if the stuff is available. got to get some brake clean to clean iacv. will get some maf cleaner while I am there. vacuumed out most of those acorns while I was in there. see larger pics here - http://www.914world.com/bbs2/index.php?act=Attach&type=post&id=577830 http://www.914world.com/bbs2/uploads/post-2460-1476462756_thumb.jpg Link to comment Share on other sites More sharing options...
GTEASER Posted October 14, 2016 Share Posted October 14, 2016 Clean the IACV with carb or throttle body cleaner, or SeaFoam. Brakleen won't do much. While you're in there, check carefully for vac leaks. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
jimkelly1964 Posted October 14, 2016 Author Share Posted October 14, 2016 my other car is a Porsche 914 and when they have their orig fuel injected engines in then, vacuum leaks is a big problem with them too. looking at the hoses I removed to remove my iacv, it seems they all got hard from heat and age. I can see how old hoses can cause leaks. I hit one hose with a hammer to break loose the plastic pcv connector broken inside it, and the hose broke like it was plastic itself. gonna replace, hoses, 807512612, 807519082, 807515842, and pcv connector 11821aa221, at minimum. iacv clean and tomorrow i will remove and clean maf, got the right stuff. note: when cleaning iacv, be sure to have some straight brushes, a toothbrush won't do. Link to comment Share on other sites More sharing options...
RumbleRumble Posted November 1, 2016 Share Posted November 1, 2016 Did any of that stuff do it? Link to comment Share on other sites More sharing options...
jimkelly1964 Posted November 2, 2016 Author Share Posted November 2, 2016 have not rcvd my new hoses, so i have not yet reinstalled the iacv. i also have not yet cleaned the maf. i will withing the next week or two though. Link to comment Share on other sites More sharing options...
Smithcraft Posted November 4, 2016 Share Posted November 4, 2016 Definitely change your plugs, and plug wires while you're at it. I had some problems a bit after I bought my 94, and I replaced the TPS, which did rattle, with a salvage yard TPS but the problem continued. Finally, and thinking something similar that the car had been maintained, I changed the plugs to find they were way out of gap. The previous owner had decided to have super long lasting plugs put in a super long time prior. Fortunately the NGK V-Power spark plugs are pretty inexpensive. SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
jimkelly1964 Posted November 7, 2016 Author Share Posted November 7, 2016 cleaned iavc and maf. i received the hoses and gasket, and stopped at advanceauto to get one hose similar to the big hose to use in place of the no longer big hose (the hose from iacv to intake tube. i put it back together, it ran for a bit but then stalled. i restarted it and it stalled right away. this weekend i am gonna put a fuel pressure guage on it, to see if maybe my fuel pressure is low. *note: fwiw: the iacv on an automatic car is different than the iacv on a manual car. thus some of the hoses are different too. Link to comment Share on other sites More sharing options...
jimkelly1964 Posted November 19, 2016 Author Share Posted November 19, 2016 ok, fuel pressure guage installed. -- car seems to run at about 28 psi initially but I just let it run for about an hour and noticed pressure at about 24 psi and engine running a but rough. when I shut down engine I noticed pressure rose to about 32 psi. seems engine smoothed out some when I opened the throttle. car is not registered currently, so this is all in driveway, parked. thoughts? note car seems to not be stalling out anymore, but my test is limited to simply let care run parked. Link to comment Share on other sites More sharing options...
Smithcraft Posted November 20, 2016 Share Posted November 20, 2016 I couldn't figure out what you were talking about, but then I notice you titled your post, and are talking about fuel pressure. SC 1994 Legacy MI 2008 Legacy GT specB 2023 Crosstrek Limited Link to comment Share on other sites More sharing options...
RumbleRumble Posted November 20, 2016 Share Posted November 20, 2016 Maybe it's a bad IACV or TPS in general. Link to comment Share on other sites More sharing options...
