Shello007 Posted February 8, 2017 Share Posted February 8, 2017 @05RedGTWagon - If your vehicle uses the low beam bulb as a DRL (daytime running light) bulb, then you would need to get the canbus module. If your vehicle has a dust cover on the back of the headlight then you would most likely need to drill a hole in that cover. Both our LED and HID kits will come with a rubber grommet that will enable you to reseal the housing. @drunkinmonk - If your low beam is used as a DRL then you would need to purchase the canbus module. The canbus module basically modulates the power going to the LED driver or HID ballast, and ensures that it sees a stable 12V. Steve Which is it? those are two contradictory statements. My package came in the mail today. You made me purchase the CANbus units in vain? I also drive an 05 LGT withe low beam DRL. Link to comment Share on other sites More sharing options...
XenonDepot Posted February 9, 2017 Author Share Posted February 9, 2017 @Shello007 - If you plan on installing this kit in an application that is used as a DRL without the module then the lights will flicker extremely fast when in DRL mode (which makes it appear that the bulb is actually operating dimmer, but really it's flickering extremely fast). The PWM / Canbus ensures that the light does not flicker in DRL mode and the LED bulb functions at regular intensity with out any flicker in DRL mode -- basically the light can only function at one intensity with no flicker. Steve Link to comment Share on other sites More sharing options...
Shello007 Posted February 11, 2017 Share Posted February 11, 2017 ^I'm an idiot. Sorry. I read those sentences 5 times before quoting- saw they were different. The Mandela effect is real. Link to comment Share on other sites More sharing options...
Shello007 Posted February 11, 2017 Share Posted February 11, 2017 Install is pretty straight forward. I just Cannot get the dust covers to fit with the heat sink strips. I splayed them in all directions, just wouldn't fit. Link to comment Share on other sites More sharing options...
