XenonDepot Posted September 19, 2016 Share Posted September 19, 2016 Introducing the XenonDepot Xtreme LED headlight and fog light kits! http://artoflightindustries.com/xd/images/design/forum/xd-forum-xtremeled-1.jpg http://artoflightindustries.com/xd/images/design/forum/xd-forum-xtremeled-2.jpg http://artoflightindustries.com/xd/images/design/forum/xd-forum-xtremeled-3.jpg Learn more about the Xtreme LED Kits Link to comment Share on other sites More sharing options...
quick4dr Posted September 21, 2016 Share Posted September 21, 2016 fits inside our housings? Link to comment Share on other sites More sharing options...
XenonDepot Posted September 21, 2016 Author Share Posted September 21, 2016 fits inside our housings? The previous generation LED kits did, and these are similar in size. The nice thing about these units is that they are clockable, so you can optimize the position of the diodes. - Danny Link to comment Share on other sites More sharing options...
racerdave Posted September 22, 2016 Share Posted September 22, 2016 So which ones would we order? Link to comment Share on other sites More sharing options...
XenonDepot Posted September 22, 2016 Author Share Posted September 22, 2016 @racerdave - what year is your vehicle? Check out our "Shop By Vehicle Lighting Guide" Steve Link to comment Share on other sites More sharing options...
racerdave Posted September 22, 2016 Share Posted September 22, 2016 never mind... I misread the numbers on the site Link to comment Share on other sites More sharing options...
racerdave Posted September 22, 2016 Share Posted September 22, 2016 thx :-) Link to comment Share on other sites More sharing options...
racerdave Posted September 22, 2016 Share Posted September 22, 2016 With or without CANbus for a 2005 Legacy? Link to comment Share on other sites More sharing options...
XenonDepot Posted September 27, 2016 Author Share Posted September 27, 2016 With or without CANbus for a 2005 Legacy? Did you want to upgrade your low or high beams? And do you have daytime running lights? -Danny Link to comment Share on other sites More sharing options...
ExitVisa Posted September 27, 2016 Share Posted September 27, 2016 I'm thinking of getting the 9005 Extreme LED kit for the high beams on my 2007 spec B. I'm still new to Legacys so I don't know if it requires the CANBUS option. Link to comment Share on other sites More sharing options...
XenonDepot Posted September 28, 2016 Author Share Posted September 28, 2016 @ExitVisa - Does your vehicle use the high beam bulb as a DRL? If so, you may need to select the "canbus" option to avoid any flickering. Steve Link to comment Share on other sites More sharing options...
XenonDepot Posted September 28, 2016 Author Share Posted September 28, 2016 Hi Everyone! Check out these fresh pics of the 9005 Xtreme LED Kit compared to the stock halogen: http://artoflightindustries.com/xd/images/XT_LED_Comparison/Camry_01.jpg http://artoflightindustries.com/xd/images/XT_LED_Comparison/Camry_02.jpg http://artoflightindustries.com/xd/images/XT_LED_Comparison/Camry_03.jpg http://artoflightindustries.com/xd/images/XT_LED_Comparison/Camry_04.jpg Link to comment Share on other sites More sharing options...
racerdave Posted September 30, 2016 Share Posted September 30, 2016 Did you want to upgrade your low or high beams? And do you have daytime running lights? -Danny Lows and no DRLs (disconnected relay) Link to comment Share on other sites More sharing options...
CTGT Posted October 2, 2016 Share Posted October 2, 2016 Are the lumen ratings per bulb of per pair? Do you have any photos of a down the road view comparing halogen low beam and LED? Link to comment Share on other sites More sharing options...
XenonDepot Posted October 3, 2016 Author Share Posted October 3, 2016 @racerdave - No canbus needed for your vehicle. CTGT - The bulbs are rated at approximately 1800-1900 lumens per bulb (low beam only bulbs). Just got this vid: https://www.youtube.com/watch?v=qDt7cCgVCjI&feature=youtu.be Steve Link to comment Share on other sites More sharing options...
CTGT Posted October 7, 2016 Share Posted October 7, 2016 How does the brightness of these compare with your prior model LED that this replaced? Link to comment Share on other sites More sharing options...
XenonDepot Posted October 7, 2016 Author Share Posted October 7, 2016 Hi, These are 22% brighter then the previous version. Steve Link to comment Share on other sites More sharing options...
CTGT Posted October 10, 2016 Share Posted October 10, 2016 Thanks Steve! Are the clockable bases made out of metal or plastic? Hard to tell from the photos. Also, would it be OK to put the ballast in the headlight housing and then put the dust caps back on without air holes or modified dust caps? I'm assuming not canbus needed on a 2010 LGT low beam, can you confirm? Anyone have photos of these on an LGT? Link to comment Share on other sites More sharing options...
XenonDepot Posted October 11, 2016 Author Share Posted October 11, 2016 @CTGT - There is no plastic on the bulb -- only aluminum. We suggest putting the driver outside of the headlight housing as it gets warm. We do have customers that place everything in the headlight housing, but we suggest mounting it outside so that the heatsink doesn't get warmed up by the driver as well.. Steve Link to comment Share on other sites More sharing options...
XenonDepot Posted November 8, 2016 Author Share Posted November 8, 2016 Hi Everyone! Check out these awesome shots of an H4 Xtreme LED Kit in action, as well as the comparison between the Xtreme LED kit and the stock halogen bulbs! Stock H4 (low beam): http://artoflightindustries.com/xd/images/vehicles/16_Tundra_XtremeLED/16_tundra_StockH4.jpg Xtreme H4 LED Headlight Kit (low beam): http://artoflightindustries.com/xd/images/vehicles/16_Tundra_XtremeLED/16_TundraH4_LED.jpg Stock H4 pattern (high beam): http://artoflightindustries.com/xd/images/vehicles/16_Tundra_XtremeLED/16_tundra_StockH4HighBeam.jpg Xtreme H4 LED Headlight Kit pattern (high beam): http://artoflightindustries.com/xd/images/vehicles/16_Tundra_XtremeLED/16_tundra_LEDH4HighBeam.jpg Stock H4 pattern (low beam): http://artoflightindustries.com/xd/images/vehicles/16_Tundra_XtremeLED/16_tundra_StockH4Beam.jpg Xtreme H4 LED Headlight Kit pattern (low beam): http://artoflightindustries.com/xd/images/vehicles/16_Tundra_XtremeLED/16_tundra_LEDH4Beam.jpg Link to comment Share on other sites More sharing options...
KIWILEG Posted November 9, 2016 Share Posted November 9, 2016 thats awesome.. i have a 1998 bh5 legacy wagon (right hand drive) can you link the kit i would need to retrofit please Link to comment Share on other sites More sharing options...
XenonDepot Posted November 9, 2016 Author Share Posted November 9, 2016 @KIWILEG - Does your vehicle use an H4 halogen bulb? If so, this is the link to the H4 LED kit featured above. Steve Link to comment Share on other sites More sharing options...
KIWILEG Posted November 9, 2016 Share Posted November 9, 2016 No it has an HID and a smaller bulb below it. Link to comment Share on other sites More sharing options...
XenonDepot Posted November 9, 2016 Author Share Posted November 9, 2016 Hi, I'm sorry, but I don't understand what it is you are trying to do if your vehicle has OEM HID headlights. Are you looking for better bulbs to replace the HID bulbs that you currently have installed? Steve Link to comment Share on other sites More sharing options...
KIWILEG Posted November 10, 2016 Share Posted November 10, 2016 http://trademe.tmcdn.co.nz/photoserver/full/514340022.jpg these are what i have now but i just hate them Link to comment Share on other sites More sharing options...
