Erroneous boost values on APv3
scoobyscoodle
I have a Defi boost gauge in my car hooked up to the MAP reference line off of my BPV. It reads the same boost my car was tuned to(~19psi in S#), so everything mechanically is fine.
However, when monitoring boost on my APv3, when I go WOT and hit full boost my max boost value on the AP shoots up to 35-40psi (vacuum as well). Any idea what this could be? Failing MAP sensor? For some reason under partial throttle and boost <10-12psi the AP reads accurately.
TD Boost Error is similarly effected.
