Andy_Mac Posted August 6, 2016 Share Posted August 6, 2016 Any of you guru's know what this log may be telling me is wrong? LV used to work on the laptop but recently comes up with a fault telling me to look into this log. Purchased a Nexus 7 recently which is running BTSSM and can access a LV from there so wouldn't have thought it was an issue with the Tactrix cable. Have also tried redownloading LV which didn't help either https://drive.google.com/file/d/0B_0U1z9r1ODccUFra0oyanBfU1E/view?usp=sharing 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
compsurge Posted August 6, 2016 Share Posted August 6, 2016 What Java are you using? I had an issue where LV would work and RomRaider would not. I had 32-bit and 64-bit loaded. There is a way to force the 32-bit to load in the command. http://legacygt.com/forums/showpost.php?p=5234405&postcount=34 Not sure if that helps at all, but it has been so long since I pulled a LV. Link to comment Share on other sites More sharing options...
Andy_Mac Posted August 6, 2016 Author Share Posted August 6, 2016 Not sure that applies to the standalone LV application. Doing a fresh windows 7 install today since i'm sick of windows 10 so i'll see if that helps at all, otherwise i'm at a loss how to fix it. 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
Andy_Mac Posted August 7, 2016 Author Share Posted August 7, 2016 Still not working with a fresh windows install and a new usb cable between the laptop and Openport. 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
rhino6303 Posted August 8, 2016 Share Posted August 8, 2016 Can you verify that the tactrix cable works with the laptop? You might have to delete and re-install the drivers for the tactrix cable. Link to comment Share on other sites More sharing options...
MasAyinde Posted August 19, 2016 Share Posted August 19, 2016 LV is unnecessary with the most recent version of RR logger. The tools menu has a Learning View Table option Link to comment Share on other sites More sharing options...
