6th Gen Lighting Threads
It seems that a lot of threads in the 6th gen forum area relate to lights/lighting. So to try and reduce the number of duplicate threads here's a "master" index with links to all the current lighting threads.
Please search/read through the existing threads before starting a new thread as likely the topic has been discussed/covered before.
Also please don't ask questions in this thread. It's intended as an index only. Ask your questions in the relevant thread linked below.
OEM Light Bulb Specs
2015 Legacy Bulb Replacement: http://legacygt.com/forums/showthread.php/2015-legacy-bulb-replacement-229862.html
Headlight Upgrades
2015 Legacy Bulb Replacement: http://legacygt.com/forums/showthread.php?t=229862
Few questions on replacing the halogen DRL with LED DRL: http://legacygt.com/forums/showthread.php?t=254495
LED Headlights: http://legacygt.com/forums/showthread.php?t=253870
HID install - XenonDepot Philips 4300k: http://legacygt.com/forums/showthread.php?t=247930
Iihs headlight ratings: http://legacygt.com/forums/showthread.php?t=251450
Xenon Depot 9005 LED High Beam/DRL Review: http://legacygt.com/forums/showthread.php?t=245832
OPT7 Led vs. PIAA Halogen vs. OEM: http://legacygt.com/forums/showthread.php?t=248714
Replacing Halogen High Beams with LED's: http://legacygt.com/forums/showthread.php?t=242631
low beam H11 HID from Xenon Depot: http://legacygt.com/forums/showthread.php?t=241941
The "next gen" in the led headlight trend:http://legacygt.com/forums/showthread.php?t=244743
Light Upgrade questions: http://legacygt.com/forums/showthread.php?t=246406
HID Upgrade on 2.5i Limited: http://legacygt.com/forums/showthread.php?t=233107
OLM HP Gen 2 Passive Cooling led low beams: http://legacygt.com/forums/showthread.php?t=242554
Are the LED high beams better than OEMs halogen?: http://legacygt.com/forums/showthread.php?t=243766
HID headlights vs. LED on my Limited - http://legacygt.com/forums/showthread.php/hid-headlights-vs-led-my-limited-254049.html?t=254049&highlight=LED
Led 9005 high beams - http://legacygt.com/forums/showthread.php/led-9005-high-beams-250236.html?t=250236&highlight=LED
RX350 AFS Bixenon Retrofit (page 11-13) - http://legacygt.com/forums/showthread.php/im2c0ols-15-cwp-legacy-ltd-ride-journal-lots-pictures-229871p11.html?highlight=im2c0ol+retrofit
Lighting Observations and Questions (3.6R Limited with HID) - http://legacygt.com/forums/showthread.php/lighting-observations-and-questions-255831.html
Rally/Spot/Specialist Lights
Light Bar Installation *With Pictures* : http://legacygt.com/forums/showthread.php?t=253876
Legacy Rally Light Bar: http://legacygt.com/forums/showthread.php?t=250961
Hella 500FF Install: http://legacygt.com/forums/showthread.php?t=253182
Vol Fireman Responding lights: http://legacygt.com/forums/showthread.php?t=243241
Fog Lights
Fog as DRL: http://legacygt.com/forums/showthread.php?t=248136
Steering Responsive Fog Lights .... : http://legacygt.com/forums/showthread.php?t=250344
Cheap fog light bulbs: http://legacygt.com/forums/showthread.php?t=250796
Fog light kit: weekend install project: http://legacygt.com/forums/showthread.php?t=230637
fog bulb replacement: http://legacygt.com/forums/showthread.php?t=249959
The Illustrious Chrome Fog Surround: http://legacygt.com/forums/showthread.php?t=249449
Fog light as DRL : http://legacygt.com/forums/showthread.php?t=231383
How to: Fog lights on with unlock/welcome lights: http://legacygt.com/forums/showthread.php?t=246290
Fog Light Kit Installation Guide!: http://legacygt.com/forums/showthread.php?t=243285
Steering Responsive Fog Lights: http://legacygt.com/forums/showthread.php?t=244935
Don't buy the fog light kit!: http://legacygt.com/forums/showthread.php?t=236759
2015 Legacy fog light installation : http://legacygt.com/forums/showthread.php?t=244354
OEM Fog Light installation: http://legacygt.com/forums/showthread.php/oem-fog-light-installation-254731.html
Morimoto Fogs/Good or Bad? - http://legacygt.com/forums/showthread.php/morimoto-fogs-good-badi-253155.html?t=253155&highlight=LED
Head light controls
Auto headlight question?: http://legacygt.com/forums/showthread.php?t=254110
Night time turning help: http://legacygt.com/forums/showthread.php?t=247413
Changing the 'Auto' headlight setting to be HID?: http://legacygt.com/forums/showthread.php?t=243498
Did approach lighting replace puddle lights from last gen?: http://legacygt.com/forums/showthread.php?t=245166
How to turn off approach lighting when opening/closing doors?: http://legacygt.com/forums/showthread.php?t=244858
Approach lighting, does it come from the mirrors?: http://legacygt.com/forums/showthread.php?t=244236
Auto Headlights Issue: http://legacygt.com/forums/showthread.php/auto-headlights-issue-254722.html
Limited OEM HID and Auto Headlight mode: http://legacygt.com/forums/showthread.php/limited-oem-hid-and-auto-headlight-mode-256301.html
Indicators / Turn Signals
Diode Dynamics 2015+ Subaru Legacy Tail as Turn™ +Backup Module! See Install Video! - http://legacygt.com/forums/showthread.php/diode-dynamics-2015-subaru-legacy-tail-turn-backup-module-see-255759.html
Side Mirror with Integrated Turn Signal: http://legacygt.com/forums/showthread.php?t=243565
Led help: http://legacygt.com/forums/showthread.php?t=253804
LED's for Turn Signals: http://legacygt.com/forums/showthread.php?t=244408
BRZ tail as turn kit on Legacy? Maybe...stay tuned...: http://legacygt.com/forums/showthread.php?t=244185
Anybody using led bulbs in the rear turn signals? - http://legacygt.com/forums/showthread.php/anybody-using-led-bulbs-rear-turn-signalsi-253641.html?t=253641&highlight=LED
Interior LEDs
Prolightz V2.0 Interior LED Kit Review: http://legacygt.com/forums/showthread.php?t=251204
LED's interior and exterior. List?: http://legacygt.com/forums/showthread.php?t=233350
Dim map and dome LEDs: http://legacygt.com/forums/showthread.php?t=250748
15' Legacy/Outback Footwell Illumination Kit.: http://legacygt.com/forums/showthread.php?t=237567
Footwell illumination for under $10 : http://legacygt.com/forums/showthread.php?t=243789
2016 OEM Footwell Interior Illumination Kit: http://legacygt.com/forums/showthread.php?t=243883
Cup holder lights, best place to tap in?: http://legacygt.com/forums/showthread.php?t=244846
DD vs. XD - http://legacygt.com/forums/showthread.php/dd-vs-xd-255307.html
Zevo DRL LED strips - http://legacygt.com/forums/showthread.php/zevo-drl-led-strips-255255.html?t=255255&highlight=LED
Info on installing LED bulbs in your Subaru - http://legacygt.com/forums/showthread.php/info-installing-led-bulbs-your-subaru-248756.html?t=248756&highlight=LED
Daytime Running Lights (DRL)
Cost to install LED DRLs at dealer or elsewhere?: http://legacygt.com/forums/showthread.php?t=252625
Morimoto and subiespeed C light LED bulb for premium/base: http://legacygt.com/forums/showthread.php?t=244347
DIY: 15'+ DRL Disable: http://legacygt.com/forums/showthread.php?t=229147
DRL on side mirror indicator: http://legacygt.com/forums/showthread.php?t=251331
15'+ C-LED as DRL solved: http://legacygt.com/forums/showthread.php?t=239825
DRL dimming: http://legacygt.com/forums/showthread.php?t=249036
Successful mod Boomerang's (CLEDS) as DRLs: http://legacygt.com/forums/showthread.php?t=248324
Need CLed for testing: http://legacygt.com/forums/showthread.php?t=247147
boomerang light on Legacy: http://legacygt.com/forums/showthread.php?t=246361
V3 Triton Switchbacks as DRL : http://legacygt.com/forums/showthread.php?t=245657
How to always keep on the Upper led lights that are like a strip: http://legacygt.com/forums/showthread.php?t=240113
Few questions on replacing the halogen DRL with LED DRL - http://legacygt.com/forums/showthread.php/few-questions-replacing-halogen-drl-led-drl-254495.html?t=254495&highlight=LED
Feedback on LED DRLs purchased - http://legacygt.com/forums/showthread.php/feedback-led-drls-purchased-254906.html?t=254906&highlight=LED
Cost to install LED DRLs at dealer or elsewhere? - http://legacygt.com/forums/showthread.php/cost-install-led-drls-dealer-elsewherei-252625.html?t=252625&highlight=LED
7440 to 7443 switchback LED vs. V3 Triton Switchbacks as DRL - http://legacygt.com/forums/showthread.php/7440-7443-switchback-led-vs-v3-triton-switchbacks-drl-255402.html
Tinted head/tail lights
Wrapping headlights and tail lights...soon: http://legacygt.com/forums/showthread.php?t=253611
License Plate LEDs
License Plate LED bulb replacement: http://legacygt.com/forums/showthread.php?t=251218
Third Brake Light
Third Brake light wire: http://legacygt.com/forums/showthread.php?t=243984
The We Have too Many Light Threads Thread
Lighting Threads: http://legacygt.com/forums/showthread.php?t=245844
Edited by tigger73
  • Replies 324
  • Created
  • Last Reply
Top Posters In This Topic
  • 2 weeks later...
To everyone who has the 2.5l and doesn't want HID or LED conversion kits and simply wants a plug and play LED halogen bulb that performs just as good as the HID and LED , buy the H11 LED 6K PIAA halogen bulbs, even tho they are quite pricy for 299$ , it's the closest match to your LED's and its legal, and best of all plug and play .
http://www.piaa.com/LEDbulb
Figured I'd throw a picture of my Subispeed OLM HP Gen2 6000k Low Beam LED's in case anyone was wondering what they looked like or just for reference. They're Plug n Play and are super easy to install. Also have a great cut off as well.
12903679_10153881000501858_403827763_o.thumb.jpg.a5e082c6e75cd205f37509c4795fb86f.jpg
12915270_10153884160306858_915555867_o.thumb.jpg.707ef210a53bda6b15baf9242d24361d.jpg
12940972_10153886204746858_1890673711_o.thumb.jpg.58a440f764edc88b5d1586ec39e514de.jpg
Very nice, where did you purchase those ? Are they just on your lowbeam ( during night) or do you have another pair of them installed as your DRL as well ?
Edited by denokarter
Just low beams, and actually bought them from a member here Robstunner who bought his legacy from me lol. But he bought them on Subispeed.com
We have a new Legacy in the studio this week!
Very excited to post some of the new products we've developed for the Legacy. We will also have installation videos for each location as well
Nick C.
Ive been waiting for this all my life... :lol:
http://cf.chucklesnetwork.com/items/1/1/7/1/3/1/original/hey-relax-buddy-im-working-on-it.jpg
Just a few more weeks! Made in USA as well :)
Thanks,
Nick C.
John C.
Diode Dynamics
just a few more weeks! Made in usa as well :)
thanks,
nick c.
take my money take my money!
But in all serious please let me know as soon as you guys develop them, i'll be ordering them right away. I've got a guy doing the demon eye install in my lights so i'm gonna hold off for now until these are ready. :)
Edited by RobbieGT
Thanks,
Nick C.
Please do take my money as well!!! I cannot wait to get these C lights brighter! Best news I've heard all day!
Here's two helpful installation videos for the Legacy that we just put together:
[ame=http://www.youtube.com/watch?v=oTouXHyPtyM]How to Install 2003-2016 Subaru Legacy Backup & License Plate LEDs - YouTube[/ame]
[ame=http://www.youtube.com/watch?v=4eIC-SmBNlM]2016 Subaru Legacy DRL & Front Turn Signal LEDs - YouTube[/ame]
We will have more products and installation videos available soon!
Thank you,
Nick C.
John C.
Diode Dynamics
Dumb question: if 6 ohm resistors are required per bulb to fix hyper-flashing, would putting two sets of 6 ohm resistors in line with the rear bulbs and none with the fronts achieve the same end result?
16' Legacy Mods: 55w HID + XB35 5500k, LEDS upgrades, XB Type T Fog, 20mm SB.
Custom Footwell Illiminate Kit; http://legacygt.com/forums/showthread.php/15-legacy-outback-footwell-illumination-kit-237567.html
You could, but we recommend adding a resistor for each location to spread out the heat.
Thanks!
Nick C.
John C.
Diode Dynamics
