covertrussian Posted July 22, 2016 Share Posted July 22, 2016 My front LCA bushings are probably due for a replacement, if I'm gonna spend money on new ones, thinking of just getting a caster set (since the non-caster AVO ones are same price). FSM says Outbacks have 5* of caster while Legacy's have 5.91-6*. http://legacygt.com/forums/attachment.php?attachmentid=234296&stc=1&d=1469218540 More caster the better right ? When I was first creating this thread, I figured PS pump might not appreciate more caster, but seeing that Legacy's have 6* I think there should be no issues going 5.5*. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
covertrussian Posted October 17, 2016 Author Share Posted October 17, 2016 Did a dynamic camber gain graph for the 2012 Outback. http://legacygt.com/forums/attachment.php?attachmentid=239339&stc=1&d=1476667316 I think the obvious answer is yes increasing the caster by even 0.50* will make a pretty good increase in camber gain. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
TheMonaLisa Posted October 17, 2016 Share Posted October 17, 2016 More is better with 7* being the limit. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
fahr_side Posted October 17, 2016 Share Posted October 17, 2016 Just note that more caster is more load on the power steering pump. I really recommend a PS fluid cooler if increasing caster. Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
covertrussian Posted October 17, 2016 Author Share Posted October 17, 2016 Very true, though it would only add 0.50* totaling 5.58*, 2.5i Legacy's have 5.91* of caster. I don't think 2.5i Outbacks have different power steering pumps then 2.5i Legacy's so should be no problem either way. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
TheMonaLisa Posted October 17, 2016 Share Posted October 17, 2016 Just note that more caster is more load on the power steering pump. I really recommend a PS fluid cooler if increasing caster. Can you share a link to a power steering cooler kit? With Whiteline top hats and LCA bushings, I have 6.7* of caster. Sent from my iPhone using Tapatalk Link to comment Share on other sites More sharing options...
covertrussian Posted October 17, 2016 Author Share Posted October 17, 2016 Any universal one should really do the trick. I bought a $30 one for my G20 years ago because stock one wouldn't fit with FMIC. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
fahr_side Posted October 18, 2016 Share Posted October 18, 2016 I DIY'd mine. These should be pretty easy to adapt: https://www.flatironstuning.com/p-2638-sti-jdm-group-n-power-steering-cooler.aspx https://www.rallysportdirect.com/part/aftermarket-fluid-coolers/mis-mmtc-u-mishimoto-transmission-or-power-steering-fluid-cooler-universal Obligatory '[URL="http://legacygt.com/forums/showthread.php/2008-gh8-238668.html?t=238668"]build thread[/URL]' Increased capacity to 2.7 liters, still turbo, but no longer need spark plugs. Link to comment Share on other sites More sharing options...
