subieracer366 Posted July 22, 2016 Share Posted July 22, 2016 Hello all back when i got my car i disliked the rims so much that a went out and bought rims off a WRX around the time i bought the, i never had the time to put them on but this weekend i will be putting them on! I am curious if other have tried this, i have seen a white 2015 with the 2015 wrx wheels. I was hoping if you guys know if these will fit fine with any issue or scrapping! I was only able to find the one image on this forum! Thanks in advance! If anyone has images of the same combination please share them! Thanks Link to comment Share on other sites More sharing options...
freaksavior Posted July 28, 2016 Share Posted July 28, 2016 If you have the wheels, why not stick them on the car.... Plus, the wheels will have their dimisions an ET stamped on the backs. A quick google search shows me: 2015+ WRX wheels: Bolt pattern: 5x114.3 Centerbore: 56.1mm Wheel size: 17 x 8" Offset: +55mm Tire: 235/45R17 2015 Legacy: 2.5i- 17x7j stamped steel wheel with full wheel cover 2.5i Premium - 17x7 1/2 j silver 5 split-spoke alloy wheel 2.5i and 3.6 Limited- 18x71/2 jj gray machined 10 spoke alloy all models: inset 55 (2.17). PCD 114.3mm (4.50") So they will be an exact fit. Link to comment Share on other sites More sharing options...
