BBPeik Posted July 21, 2016 Share Posted July 21, 2016 That is exactly what I was going to say. If the dealer will not smog their own car then it is definitely their problem. I smogged mine before the swap with zero issues. You could just need a tech with more subie knowledge. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
JLGT Posted July 21, 2016 Author Share Posted July 21, 2016 Visited Subaru and saw their smog guy. Decal is wrong and now I have to visit a Referee. Fun! Link to comment Share on other sites More sharing options...
GTEASER Posted July 21, 2016 Share Posted July 21, 2016 Visited Subaru and saw their smog guy. Decal is wrong and now I have to visit a Referee. Fun! Subaru should fix this! They put a decal on the car that doesn't properly describe the emission equipment that the car came with. Call SOA and open a ticket, and ask to meet with the Regional Subaru Tech (the one that approves big warranty work) at the dealership. GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
Jon Deimos Posted July 21, 2016 Share Posted July 21, 2016 JLGT  I was upload the Subaru Manual on this but I cant get it to attach. Either way, from Subaru it says you have a front and rear cat; however, they are actually together in the same component. So, you have two O2 Sensors and the second one is located between the two cats. When you look at it, you will see that there is a large diameter pipe, the cat, and a sensor on the front side and a sensor in the middle. The Cats are located in front of and after the second sensor. Hope that makes sense. So, you have two cats located in the same component. In fact, you only have one part number for a cat because they are both located in the same component. The diagram they printed is not the proper diagram. I have the one from Subaru and whatever they gave you is not from Subaru. Subaru does use whats called a secondary air pump. if you have one it is on the driver side of the engine and it has two lines that fee to the back of the heads to inject air into the exhaust. A quick way to see if you have one just look at your relay box. It has a dedicated relay for it.  Hope this helps Link to comment Share on other sites More sharing options...
JLGT Posted July 21, 2016 Author Share Posted July 21, 2016 Thanks, yes I have been to the Subaru dealer which looked at the engine bay and fuse box and told me that there does not seem to be an air pump and everything looks factory. They then sent me to their smog guy, who also looked and told me that there does not seem to be an air pump and that all data doesn't show an air pump, and the OBDII diagnostics shows that the Secondary Air System is "Not Supported" no air pump. Â This is after yesterdays original smog, so 3 different visits. I have contacted Subaru and they basically just told me that they will document the issue and I should just continue with visiting the referee. Â Subaru's smog guys seemed the most helpful and said that it will probably be quicker and easier to visit the referee who will probably just sign this all off and end this fiasco. Link to comment Share on other sites More sharing options...
Scotty Posted July 21, 2016 Share Posted July 21, 2016 Where did you take it to? My 05's been smogged three times now and the visual was done from about 3 feet from the car so they never saw the missing uppipe cat, not that they can really see it. Link to comment Share on other sites More sharing options...
BBPeik Posted July 22, 2016 Share Posted July 22, 2016 I sent SOA an email about this to have a case opened. I would suggest that as many of us as possible do the same so that Subaru will understand how many have this issue. I am sure it is a real problem for them if they sold vehicles with incorrect emissions labels. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
FJuan Posted July 22, 2016 Share Posted July 22, 2016 Where did you take it to? My 05's been smogged three times now and the visual was done from about 3 feet from the car so they never saw the missing uppipe cat, not that they can really see it. The UP is not a concern for smog, they look for the main cat in the DP before the rear O2 sensor. I asked a tech this before and as long as the main cat is in place and the sniffer passes, that's all they care about. '05 - '06 models My wife's balls are delicious. Link to comment Share on other sites More sharing options...
Rutchard Posted July 22, 2016 Share Posted July 22, 2016 Subaru's smog guys seemed the most helpful and said that it will probably be quicker and easier to visit the referee who will probably just sign this all off and end this fiasco. So stupid question since I don't live in CA, how often do you have to smog your vehicle over there? Once the referee signs off on it, are you good for the next smog test? Or are you going to have to go through all this next time unless Subaru gets you an updated sticker? Also while people are contacting companies, someone should get ahold of Mitchell and let them know they have at least the wrong exhaust diagram for a 2010 GT in their system. Wonder what else they have wrong or if the 2011-12 are wrong too. Sooooo many mechanics use that system... Link to comment Share on other sites More sharing options...
GTEASER Posted July 22, 2016 Share Posted July 22, 2016 (edited) In CA, a new vehicle doesn't need to be smog checked for 6 years, until it needs registration for the 7th year since new, which is why the 2010 owners are just finding out the issue with the sticker now. From then on, it's every 2 years or at changes of ownership. Â It will make things much easier for these owners, going forward, to just get Subaru to fix the problem from the factory and to issue them a sticker with the proper, pertinent information reflecting the smog equipment that was on the car from the factory. Edited July 22, 2016 by GTEASER GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
BBPeik Posted July 22, 2016 Share Posted July 22, 2016 I need a sticker that says a a 20g, the DP and the PW intercooler are stock:lol: My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
ehsnils Posted July 22, 2016 Share Posted July 22, 2016 Most of what you need to know: https://www.dmv.ca.gov/portal/dmv/detail/vr/smogfaq Link to comment Share on other sites More sharing options...
Scotty Posted July 23, 2016 Share Posted July 23, 2016 The UP is not a concern for smog, they look for the main cat in the DP before the rear O2 sensor. I asked a tech this before and as long as the main cat is in place and the sniffer passes, that's all they care about. '05 - '06 models There's no sniffer test. Just OBD and visual. The visual is dependant on how thorough the inspector is. I have a co-worker that failed because the cat part number was incorrect. Whereas I go to places that are not as thorough. Link to comment Share on other sites More sharing options...
FJuan Posted July 24, 2016 Share Posted July 24, 2016 There's no sniffer test. Just OBD and visual. The visual is dependant on how thorough the inspector is. I have a co-worker that failed because the cat part number was incorrect. Whereas I go to places that are not as thorough. True, different parts of CA have different inspections. Here in Fresno they only look for the main rear cat and the sniffer results. My wife's balls are delicious. Link to comment Share on other sites More sharing options...
JLGT Posted July 25, 2016 Author Share Posted July 25, 2016 Visited the referee, they can't pass it due to the under-hood label.  From referee: http://i1305.photobucket.com/albums/s547/subleg/111_zps8cdvwb7v.jpg After, I went back to the Subaru dealer and supposedly they are ordering me a new label, not sure how that will go. http://i1305.photobucket.com/albums/s547/subleg/2222_zpswhft1tfx.jpg  So for now, my car will not pass smog and my registration is due in a week. If you live in California and have a 2010 GT better get started on getting yourself a new label. Lets get subaru to fix this!!!! Link to comment Share on other sites More sharing options...
BBPeik Posted July 25, 2016 Share Posted July 25, 2016 WTF. Talk about passing the buck. Well I emailed Subaru, but still have not heard back from them. Luckily I already was able to smog mine, but if I do not hear back from them soon I will be calling for sure. Seems to me that since this is their problem they should at least get you a loaner until the problem is solved. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
acumenhokie Posted July 25, 2016 Share Posted July 25, 2016 Buy used air pump from WRX/STi owner who did delete. Zip tie to engine block for visual inspection. Winning. Link to comment Share on other sites More sharing options...
BBPeik Posted July 26, 2016 Share Posted July 26, 2016 Subaru just emailed me back. Basically they said go to the dealer and have them verify your concern. I have a call into the lead tech at my dealer and he is looking into it for me. I will more than likely go by there this afternoon and have them verify my concern. I will keep you guys posted. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
JLGT Posted July 26, 2016 Author Share Posted July 26, 2016 Which Subaru dealer do you go to? Kearny Mesa? Â Also this is who I am speaking with at Subaru, he should have knowledge about these issues:Â Grant Noble Subaru of America, Inc. Customer/Retailer Services Department 1-800-SUBARU3 (1-800-782-2783) Link to comment Share on other sites More sharing options...
BBPeik Posted July 26, 2016 Share Posted July 26, 2016 I try not too go to the dealer. I am talking to the tech at El cajon. I will be sure to contact Grant. Thanks for the link. Cody at Kearny Mesa is real good. He used to be the lead tech and now is teh Manager I believe. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
BBPeik Posted July 26, 2016 Share Posted July 26, 2016 Did you go to KM? I may just try to go there since they have knowledge of the problem. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
JLGT Posted July 26, 2016 Author Share Posted July 26, 2016 Frank Bowman is helping me at KM. Link to comment Share on other sites More sharing options...
BBPeik Posted July 26, 2016 Share Posted July 26, 2016 I just spoke with the Service manager at EC and he is contacting the zone rep to see what to do. He said he will cal me back by the end of the day. Hopefully we can get this worked out. I am only about 10min away from there, so I may run by after work so they can look at it. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
GTEASER Posted July 26, 2016 Share Posted July 26, 2016 Has anyone verified that the new sticker that was ordered is correct for the equipment? GTEASER's 2012 Legacy GT - Sold GTEASER's 2009 XTeaser - Sold GTEASER's 1992 Legacy SS - Sold Link to comment Share on other sites More sharing options...
BBPeik Posted July 26, 2016 Share Posted July 26, 2016 I am guessing it is not. When it comes in we will see though. I imagine it will be the exact same sticker he has now. My someday I will be done with it thread. Link to comment Share on other sites More sharing options...
