squid372 Posted July 14, 2016 Share Posted July 14, 2016 so my current build is as follows: Aps tsr70 Turbo, Fully Forged Motor Front Mount Intercooler 1000cc Injectors, Quantum E85 Fuel Pump The issue i am facing is that the tuners in Southern Africa do not know how to get the car to run properly. I need some assistance with getting it to work. So we remapped the vehicle and it has the A/F's running in the below 10 when it starts going into boost (.6 - .7 bar). Car is over fuelling and can't boost any higher. On the previous setup with the maf in the normal position we could boost 1.8 bar and up. The reason for moving it to the cold side was due to the maf scaling going crazy as the maf housing was standard size and turbo inlet is roughly 100mm or 120mm this caused boost spikes and other issues. we are running on the OEM ECU and have not got insight into moving to another aftemarket ECU as the Exchange Rate causes a major but hurt as well as the added 70% extra for import tax. The car is running the A2UG002T ROM. The cars model is 2007 ADM Liberty GT (we call it a legacy where I live). Link to comment Share on other sites More sharing options...
solidxsnake Posted July 14, 2016 Share Posted July 14, 2016 Sounds like a job for Tuning Alliance. Get in touch with them and ask for an e-tune. Mike does great work! Link to comment Share on other sites More sharing options...
squid372 Posted July 15, 2016 Author Share Posted July 15, 2016 The issue is Rand to Dollar exchange rate. causes it to be very hefty on the pocket. Link to comment Share on other sites More sharing options...
solidxsnake Posted July 15, 2016 Share Posted July 15, 2016 So... where is the MAF in your setup? I don't understand what you mean by cold side... after the IC? If anyone's gonna help you through here, we need more details on your exact setup and maybe some logs. Link to comment Share on other sites More sharing options...
west_minist Posted July 16, 2016 Share Posted July 16, 2016 Post a pic of your setup. Link to comment Share on other sites More sharing options...
squid372 Posted July 18, 2016 Author Share Posted July 18, 2016 Will take some images and get the map from the tuner. I myself do not have a tactrix cable so I will need to find a way to pull logs using another cable. Link to comment Share on other sites More sharing options...
