90gt Posted May 24, 2016 Share Posted May 24, 2016 Hello Everyone, I am working on a 1990 legacy, 440cc sidefeed injectors. As i was installing the fuel rails and injectors i realised im missing a few screws that hold the injector caps on what bolts will fit into the rails or which bolts do you guys use? Thank You Link to comment Share on other sites More sharing options...
wtdash Posted May 25, 2016 Share Posted May 25, 2016 Hi, I'm assuming this is an EJ20G engine, if a '90 GT w/the side-feed gray top injectors? Not sure if they're the same as USA, but the fuel rails have hex bolts or philips head screws that are all the same for where the fuel lines connect to the rails/injectors, the FPR, and the caps. Take one to your local hardware store (or whatever Canadians call it) and match it up....DO GET the hex screws as the philips suck for this application. They do have different lengths, but the threads are the same. Or maybe your local Subaru dealer, if desperate. GL, TD Link to comment Share on other sites More sharing options...
90gt Posted May 25, 2016 Author Share Posted May 25, 2016 Thank you for the help wtdash Yes, it is the ej20. The couple ones i got are the phillips screw ones and i know what you mean haha. Link to comment Share on other sites More sharing options...
bcmaxx Posted May 28, 2016 Share Posted May 28, 2016 90gt. Did you use the original caps or the 440 caps? I noticed they differ. I was just going to use the 440 caps to match the injectors. Link to comment Share on other sites More sharing options...
90gt Posted May 28, 2016 Author Share Posted May 28, 2016 Im not sure, I bought the car awhile back not running, the previous owner gave me 2 sets of rails, 1 set was for the 440 injectors and 1 set was for the 550 injectors but only 1 set of caps. the set of caps he gave me seems to fit the 440 rails and injectors but i guess i wont know for sure until i get her started and check for leaks Link to comment Share on other sites More sharing options...
