vinylscratchp0n3 Posted January 14, 2016 Share Posted January 14, 2016 06 OBXT 5 speed- WOT in 2nd then sudden loss of power and a CEL. Cruise control light flashing. After driving for another 5 seconds or so it had 100% of the power again. P0340- Bad camshaft position sensor C0109- Rear ABS solenoid/circuit open C0111- ABS Motor/motor relay on failure I cleared them, then tried starting it and it didn't start until the 4th time trying, then the P0340 came right back but not the other two. Thanks for your help Link to comment Share on other sites More sharing options...
Max Capacity Posted January 14, 2016 Share Posted January 14, 2016 When you reset the ECU, you need to turn the key to ON for at least 10 seconds before you start it, or it will crank for a while before starting. google the code. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
