Outback2.5XT-05 Posted December 29, 2015 Share Posted December 29, 2015 I finally bought an oem replacement for my leaky 2005 oem TMIC. Problem was I found it on ebay. What's the best way to flush out, clean, and inspect one of these for damage or contamination with house-hold equipment? I'm trying to find someone who will let me use their parts washer but if I can use brake clean (this seems really iffy) and water or a light detergent into a rubbermaid container with good results I'd rather do that as I plan to do the install myself. Any thoughts? Link to comment Share on other sites More sharing options...
JmP6889928 Posted December 30, 2015 Share Posted December 30, 2015 You can easily flush it with water-it's just a heater core with different tanks on the ends. Just check it for flow with the water by taping up the BPV hole, and the turbo flange and filling it up with water. Flip it over and it should dump out very quickly and be empty. If not, then clean it with dishwashing liquid and water and let it sit for an hour or so and then flush it several times. The diswashing liquid will cut the grease and oil inside. Link to comment Share on other sites More sharing options...
Dispatch20 Posted December 30, 2015 Share Posted December 30, 2015 I took my intercooler into the bathtub with me. Seriously. It helped get a ton of oil out from a leaky turbo. Link to comment Share on other sites More sharing options...
Outback2.5XT-05 Posted December 30, 2015 Author Share Posted December 30, 2015 This community is awesome. Thanks folks, and a Happy New Year to you all as well! Link to comment Share on other sites More sharing options...
bnguyenbb6 Posted December 31, 2015 Share Posted December 31, 2015 You can also lay it on its side and spray brake cleaner in and let it drain through. Link to comment Share on other sites More sharing options...
rmoore5 Posted January 1, 2016 Share Posted January 1, 2016 Dishwasher, strategically positioned. With wife at work Link to comment Share on other sites More sharing options...
joeleodee Posted January 3, 2016 Share Posted January 3, 2016 Definitely don't use soap. If you have questions about that recommendation, search these forums. Link to comment Share on other sites More sharing options...
Outback2.5XT-05 Posted January 3, 2016 Author Share Posted January 3, 2016 Joeleodee, I always start each post with a really thorough search beforehand. I couldn't find anything on the subject here or on the subaruoutback forums so I made a post. Light (dish) soap seems like the best way not to corrode the foam gasket on the side tanks imo. Could you please clarify your suggestion or point me towards where I might find that answer? Thanks in advance! Link to comment Share on other sites More sharing options...
Dispatch20 Posted January 3, 2016 Share Posted January 3, 2016 Joeleodee, I always start each post with a really thorough search beforehand. I couldn't find anything on the subject here or on the subaruoutback forums so I made a post. Light (dish) soap seems like the best way not to corrode the foam gasket on the side tanks imo. Could you please clarify your suggestion or point me towards where I might find that answer? Thanks in advance! I think he was referring to an old Subaru joke about "getting soap in your intercooler." If I recall, years ago somebody on nasioc or some other site was genuinely concerned that washing a turbo Subaru and getting soap in the hood scoop would be bad for the intercooler. Dish soap is fine to help clean out any grime and oil. Just rinse it out well and leave it hanging to dry for a couple days. Link to comment Share on other sites More sharing options...
BDII Posted January 4, 2016 Share Posted January 4, 2016 Be very careful not to get soap on your intercooler. Need forum help? Private Message legGTLT Link to comment Share on other sites More sharing options...
im2c0ol Posted January 4, 2016 Share Posted January 4, 2016 Use the WEB Coil Cleaner? It's used to clean the exterior AC Condenser Unit Coil, I think it'll work awesome! http://www.lowes.com/pd_241324-1361-WCOIL_0__?k_clickID=0b3b509a-38e1-41f7-85ef-0c22b9de5cc9&store_code=2975&productId=3123857&selectedLocalStoreBeanArray=%5Bcom.lowes.commerce.storelocator.beans.LocatorStoreBean%405aa95aa9%5D&storeNumber=2975&kpid=3123857&cm_mmc=SCE_PLA-_-RoughPlumbingElectrical-_-AirFilters-_-3123857%3AWEB&CAWELAID=&CAWELAID=1368076931 16' Legacy Mods: 55w HID + XB35 5500k, LEDS upgrades, XB Type T Fog, 20mm SB. Custom Footwell Illiminate Kit; http://legacygt.com/forums/showthread.php/15-legacy-outback-footwell-illumination-kit-237567.html Link to comment Share on other sites More sharing options...
Outback2.5XT-05 Posted January 4, 2016 Author Share Posted January 4, 2016 Did I just get got? I really appreciate the advice folks. I'm still relatively new to these turbine doodads and so this community so far has been a life saver! Link to comment Share on other sites More sharing options...
Andy_Mac Posted January 4, 2016 Share Posted January 4, 2016 Not sure if its advisable or not but I just sprayed a whole load of brake cleaner in mine and kinda sloshed that around. 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness Link to comment Share on other sites More sharing options...
