OhNineGT Posted December 9, 2015 Share Posted December 9, 2015 Hey guys, I am having a problem that sounds like it is coming from the transmission. The problem only happens once the car has been rolling for about ten minutes or so. The problem is this: When turning sharp (into parking stall or making a U-turn) I get a LOUD clanking noise that also slows the car down and jolts when the click hits. It seems to be about every rotation of the wheel but the sound isn't consistent to one side or the other. Had my uncle listen to it with the hood open while I was turning and he said it sounds like it is coming from the transmission. The other thing that leads me to think it is the trans is when I down shift and the trans is slowing me down, I get a nasty grinding noise coming from the transmission. I have tried checking tie-rods (Inner and outer) and they don't seem to be the problem... Thoughts? Hoping I am off key with the idea of trans problems.. Link to comment Share on other sites More sharing options...
Moderators BarManBean Posted December 9, 2015 Moderators Share Posted December 9, 2015 You check your axles yet? "Bullet-proof" your OEM TMIC! <<Buy your kit here>> Not currently in stock Link to comment Share on other sites More sharing options...
OhNineGT Posted December 9, 2015 Author Share Posted December 9, 2015 There should be tire movement while in the air if they are bad, shouldn't there? Link to comment Share on other sites More sharing options...
GrapedrinkLGT Posted December 10, 2015 Share Posted December 10, 2015 all the wheels should be able to be spun when they're off the ground but that's not the point, holding the axle in your hand still and spinning the wheel forward or back a slight bit you should be able to detect slop in the joint, when a sloppy joint turns, it will bind causing horrid noises and sometimes great resistance is it a manual or auto, that would help.....? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 10, 2015 Share Posted December 10, 2015 With the car off the ground, if you turn one wheel, they all turn. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
OhNineGT Posted December 10, 2015 Author Share Posted December 10, 2015 It is a 5mt.. By tire movement I was more referring to play outside of normal movement.. Link to comment Share on other sites More sharing options...
OhNineGT Posted December 12, 2015 Author Share Posted December 12, 2015 Taking it to a local Subaru specialist on monday. They said they think CV joints.. I am hoping... Link to comment Share on other sites More sharing options...
OhNineGT Posted December 12, 2015 Author Share Posted December 12, 2015 Thanks for all of the help, by the way. I'll keep you guys posted. Link to comment Share on other sites More sharing options...
OhNineGT Posted December 21, 2015 Author Share Posted December 21, 2015 Shop thinks it is a bad trans. After doing some reading, I am wondering if it might be a center diff? Link to comment Share on other sites More sharing options...
GrapedrinkLGT Posted December 22, 2015 Share Posted December 22, 2015 potentially, i wonder if the car was ever towed and not on a flat bed....that'll do it Link to comment Share on other sites More sharing options...
