kkenrick Posted November 11, 2015 Share Posted November 11, 2015 Hey guys, my 05 LGT is leaking from the back of my transmission(manual) onto the downpipe. I want to make sure I order the right seal before I get into actually tearing the car apart. So would it be the output shaft seal? Thank you. Link to comment Share on other sites More sharing options...
bluesuby Posted November 12, 2015 Share Posted November 12, 2015 Just to cover the bases, I'd take a second look to make sure it's not a torn CV joint boot. That's a lot more common problem. Link to comment Share on other sites More sharing options...
Max Capacity Posted November 12, 2015 Share Posted November 12, 2015 Find it here, http://legacygt.com/forums/showthread.php/subaru-oem-parts-catalog-online-exploded-views-opposed-forces-130411.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
Max Capacity Posted November 12, 2015 Share Posted November 12, 2015 or here , http://legacygt.com/forums/showthread.php/oem-online-subaru-parts-vendors-list-42243.html Do you have these yet ? http://people.csail.mit.edu/ilh/vacation/ 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
