Please help! Lower Control Arms
Hello all,
I have identified the clunking noise in my front suspension as a failing lower control arm.
My mechanic informed me that this is a dealer only part so before I resort to the stealership, I figured I'd check here first.
I'm looking for the least expensive way to pick up a left lower control arm. Don't even car if it's used as long as it is in good shape. I'm checking local pick n pulls etc.
I'm also open to aftermarket if the cost is reasonable. Please advise!
Thanks.
Nope, Had both mine replaced a few weeks back, paid $153 for each from my trusted mechanic.
Do a google search.
http://www.bing.com/search?q=2005+subaru+lower+control+arms&src=IE-TopResult&FORM=IETR02&conversationid=&adlt=strict
Engine Build - Click Here
^they lied to you. all the bushings in the front LCA can be replaced or upgraded without replacing the arm itself.
FWIW, Mine were worn enough that the trusted mechanic didn't feel confident that new bushings would be the right way to go.
I do know I had a loose bushing for a while. So there was some banging in the front end going on. I've been going to this guy for over 25 years.
I had tried to push the bushing back in a couple times, so I have no problem with him replacing them, the front end have been great since.
Post a picture of the control arm/torn bushing. if the metal outer sleeve of the bushing is loose in the control arm, you'll have to replace the arm. 90% of the time you can just replace the bushing, but it is a serious PITA, which may be why a lot of mechanics just push to replace the whole assembly. When I say PITA, it took an experienced mechanic a few hours to remove all 4 bushings from my LCA's.
