08 LGT Coolant Temperature Gauge Not Zeroed
Windza
Anyone ever had the coolant temp gage lose zero? Appears to work fine in terms of movement with temp increase but the needle is waaaaay out of whack (points backwards at the speedo with key off)?
It was working fine just last week - it's almost as if the needle has somehow spun on the shaft (which I wouldn't have thought possible).
Anyway, before I get invasive, wanted to see if anyone has ever encountered this and maybe had a fix. Will post a photo shortly.
