new calipers w rotors.
sleepercell
I'm trying to buy a all new set of centric calipers. Says they fit lgt limited an spec. B I believe I own the less model 07 2.5 lgt w turbo. Will those. Calipers still fit?
Yes they are direct fit and identical. All 05-09 LGTs including spec Bs use the same calipers. The Tribeca also shares the same front calipers as the front of an 05-09 LGT.
After 2005 or 2006, all 2.5GT's are the Limited trim - leather, sunroof, all the goodies.
Regardless of Limited trim level, all 2.5GT's use the same brakes. Limited vs "un-limited" cover options like interior, climate control, etc. Mechanicals (engine/trans/snail) are the same.
Thank u all for the quick replys. I'm slowly upgrading my 07 lgt it's all stock but Will be a beast soon. Another. ? Will the front calipers fit the back also? If so were can I purchase them online?
Front and rear calipers are different. The fronts are larger. The left and right side are also different.
When I need replacements, I buy salvaged calipers off of EBay from junkyards. Usually $70 or less shipped per caliper.
You can also buy remanufactured ones off rockauto.com. Those are typically Subaru calipers that were cleaned up and rebuilt. They cost about 2x what a used caliper would cost.
