Subaru Liberty 1995 starting problem
Hello everyone,
Looking for an answer that no mechanic can seem to solve.
My 1995 Subaru Liberty Wagon has a random problem where it won't start. This happens after I've been driving it for a bit and then stop and then go to start it again and the ignition turns over but doesn't actually start. Has anyone had this problem before and have any idea what it is?
Thanks in advance,
Jackson
Yeah I think I can hear the fuel pump turn on but can't be 100%. The car only does it when the engine is still warm if that means anything. Did it this morning after driving 40kms and turning it off and then I left it for 5 hours and went out before and it started fine like nothing is wrong with it at all.
Cheers
Alright thank you I'll check it out. Do you have any advice or links to sort this out?
Well first I'd get your self a Haynes repair manual very good to have. But as far as testing them I don't no how you do that the only way I no is to swap them with another Subaru if u can, if not then just replace them. Very simple 2 do.
when my cam sensor went out in the GT it was very sporadic and seemingly random. it would die at a light and not start for 5 minutes, then the next morning it would not start at all. wait 20 or so minutes, mess with the wiring (red herring, im sure) and it would start up and run for 2 days straight without an issue. i traded the sensor out with the L wagon and the problem followed, the GT stopped having start issues.
as for the ECT, i dont think it will keep anything from starting, just how it will run once it is started. i ran my outback for over an hour last night with the ECT disconnected to see if it would do its stumble and/ or die thing, but without it the car ran fine.
if the car starts when cold, first thing in the morning,
but does not start when warm,
i would bet on the temp sensor.
if you have starting problems when both warm and cold,
then maybe cam ot crank sensor.
and yes, those two can be intermittent.
i was having an intermittent issue with my GT sputtering out and not starting on crank sensor, found out that when i replaced the sensor with the one off the extra motor i had, either the bolt was different length or the sensor is a different height because the sensor was rattling around loose after i tightened it down. once i got that sucker immobile i havent had an issue at all.
