MarkP1986 Posted July 29, 2015 Share Posted July 29, 2015 Me and my buddy were tearing apart his engine (maybe a little too quickly), with oily hands he dropped one of the cams on the concrete floor. After cleaning and inspecting the cam under a light we think we see a small crack in the camshaft. I found a company in New England that claims they can weld a cracked camshaft: http://camsnortheast.net/services-view/camshaft-welding/ My question is has anyone ever had a camshaft welded?? If so any running issues? And did it hold up? Link to comment Share on other sites More sharing options...
whitetiger Posted July 29, 2015 Share Posted July 29, 2015 is buying a new cam that much more expensive than having a repair done. a quick search yeilds an intake cam being worth $160 new from a dealer. to me that is cheap compared to a potential failure from having it welded. Link to comment Share on other sites More sharing options...
doobaruGT Posted July 29, 2015 Share Posted July 29, 2015 ^this Also, if it's welded, how does it remain balanced. That would be pretty awful at such high rpm's. Do it right, do it once Updated parts list since original part-out here. Original Full part-out of my LGT HERE! Link to comment Share on other sites More sharing options...
gto7419 Posted July 30, 2015 Share Posted July 30, 2015 Lol, I have a friend who welded up his lobes and then ground them down for more lift. Was a junkyard sbc build. I wouldn't risk it in a subie motor. These things are rather delicate in regards to parts that do not have very good tolerances. Buy a used cam from the forums. Link to comment Share on other sites More sharing options...
covertrussian Posted July 30, 2015 Share Posted July 30, 2015 Like others said it's not worth the risk, you can probably get a set of cams fairly cheap here from someone that upgraded to bigger cams. 05 LGT 16G 14psi 290whp/30mpg (SOLD) 12 OBP Stock 130whp/27mpg@87 Oct 00 G20t GT28r 10psi 250whp/36mpg 22 Ascent STOCK Link to comment Share on other sites More sharing options...
rmoore5 Posted July 30, 2015 Share Posted July 30, 2015 I would imagine if it cracked it, it is also bent. Link to comment Share on other sites More sharing options...
MarkP1986 Posted July 30, 2015 Author Share Posted July 30, 2015 Thanks for all the replies! My friend is a bit of a nut when it comes to these things, wants to keep it original. I don't see the point myself but that's what he wants. Maybe I will just buy him a new cam and tel him its the old one that was repaired and parkerized. lol Link to comment Share on other sites More sharing options...
Max Capacity Posted July 30, 2015 Share Posted July 30, 2015 I agree that is the better way to go. There is a good chance it is bent. I know back in the early day's of Hot Rodding, guy's would weld material on the cams and regrind them. That's where companies like Crane, Isky, Eagle, etc got their start. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
MarkP1986 Posted July 31, 2015 Author Share Posted July 31, 2015 Ya, if its bent that would be a game changer for sure! You might be able to weld it but you can't re-bend it! I'll let you all know if he goes with the weld method. Link to comment Share on other sites More sharing options...
