orndog Posted August 12, 2015 Share Posted August 12, 2015 That is the first time I have seen dates and VINs of when the fix was in place. However, that is still the older version of the TSB. The accepted repair was changed to 'replace short block' a while back. Link to comment Share on other sites More sharing options...
hmmrdwn Posted August 16, 2015 Share Posted August 16, 2015 This has probably been posted. It's the consumer reports video... Link to comment Share on other sites More sharing options...
YeuEmMaiMai Posted August 16, 2015 Share Posted August 16, 2015 wow worst case for Subaru is 17% for H6 Audi is 40% or more.. some porches are 68%... Link to comment Share on other sites More sharing options...
norcalgeek Posted August 19, 2015 Share Posted August 19, 2015 I have a 2014 Legacy 4 cyl. I love my car and last may I drove to LA and back(13 hundred miles) and a week later while my wife was driving the oil light came on. We were down a little over a quart. Seems like a lot for one trip on a car that had less than 50k on it. I continued to watch it and it has been going through oil beyond what I AM COMFORTABLE with. I take it in today for an oil consumption test after another trip to LA. Oil is down, but I don't think it's in guidelines of needing their fix(which is new short block from what I understand). The dip stick definitely seemed overfilled when I started my test. Hope this turns out well for this young of a car(I do have 64k on it). ncg Link to comment Share on other sites More sharing options...
ssbtech Posted August 19, 2015 Share Posted August 19, 2015 While there's no excuse for not regularly checking oil levels, there's really no excuse for the oil light to be coming on during regular oil change intervals. Link to comment Share on other sites More sharing options...
orndog Posted August 19, 2015 Share Posted August 19, 2015 I have a 2014 Legacy 4 cyl. I love my car and last may I drove to LA and back(13 hundred miles) and a week later while my wife was driving the oil light came on. We were down a little over a quart. Seems like a lot for one trip on a car that had less than 50k on it. I continued to watch it and it has been going through oil beyond what I AM COMFORTABLE with. I take it in today for an oil consumption test after another trip to LA. Oil is down, but I don't think it's in guidelines of needing their fix(which is new short block from what I understand). The dip stick definitely seemed overfilled when I started my test. Hope this turns out well for this young of a car(I do have 64k on it). ncg I would have made them drain down to the proper full mark. Link to comment Share on other sites More sharing options...
hmmrdwn Posted August 22, 2015 Share Posted August 22, 2015 I have a 2014 Legacy 4 cyl. I love my car and last may I drove to LA and back(13 hundred miles) and a week later while my wife was driving the oil light came on. We were down a little over a quart. Seems like a lot for one trip on a car that had less than 50k on it. I continued to watch it and it has been going through oil beyond what I AM COMFORTABLE with. I take it in today for an oil consumption test after another trip to LA. Oil is down, but I don't think it's in guidelines of needing their fix(which is new short block from what I understand). The dip stick definitely seemed overfilled when I started my test. Hope this turns out well for this young of a car(I do have 64k on it). ncg Your feelings are totally normal. Weird it happened on a 2014. They didn't seal the dipstick with tape? Some dealers do that to prevent customer interference. Subaru can produce engines that don't use oil and still get good mileage. Our 2011 goes 5-6k between oil changes without using. Link to comment Share on other sites More sharing options...
DC65 Posted August 23, 2015 Share Posted August 23, 2015 in the last 10 years, I have owned or own the following 1986 Subaru GL (200k+ miles) 1996 Land Rover Discover (140k+ miles) 2002 Jeep Wrangler (40k+ miles) 2003 Subaru Legacy (135k+ miles) 2003 Dodge Durango (150k+ miles) 2004 Subaru Outback Wagon (140k+ miles) 2004 Dodge Neon (150k+ miles) 2004 Subaru Legacy (118k+ miles) with regular maintenance, PCV replacement, etc. I run Amsoil oil and gear lube in the engine transmission and difs with 10k mile change intervals with no oil loss after 10k miles. Even the abused GL didn't burn oil after I tuned it up and flush the system, replaced valve cover gaskets. Proper maintenance and treatment is needed. Most of the new buyers don't do that however. Link to comment Share on other sites More sharing options...
hmmrdwn Posted August 24, 2015 Share Posted August 24, 2015 in the last 10 years, I have owned or own the following 1986 Subaru GL (200k+ miles) 1996 Land Rover Discover (140k+ miles) 2002 Jeep Wrangler (40k+ miles) 2003 Subaru Legacy (135k+ miles) 2003 Dodge Durango (150k+ miles) 2004 Subaru Outback Wagon (140k+ miles) 2004 Dodge Neon (150k+ miles) 2004 Subaru Legacy (118k+ miles) with regular maintenance, PCV replacement, etc. I run Amsoil oil and gear lube in the engine transmission and difs with 10k mile change intervals with no oil loss after 10k miles. Even the abused GL didn't burn oil after I tuned it up and flush the system, replaced valve cover gaskets. Proper maintenance and treatment is needed. Most of the new buyers don't do that however. At 10K mile oil change intervals...you would have added 8 quarts of oil to the affected Subaru engines with the loose/aligned rings. Even Amsoil wouldn't help that. Blowby will continue regardless of the type of oil, unless you use a heavier grade or fix the rings. Link to comment Share on other sites More sharing options...
shoenfield Posted September 10, 2015 Share Posted September 10, 2015 Consumer Reports: Excessive oil consumption http://www.consumerreports.org/cro/magazine/2015/06/excessive-oil-consumption/index.htm Dealership near me in NJ said they had a few instances of excessive oil consumption mainly on manual transmissions. Link to comment Share on other sites More sharing options...
