nn2s2u Posted May 22, 2015 Posted May 22, 2015 I have a squeak coming from my 96. 4EAT trans and 2.2L engine with 190k. The squeak sounds very similar to a something in the braking system rubbing or scraping when stopping. I spent a day cleaning and the pads/rotors and shields because it sounded like that was the problem. Noise only happens when braking. It might be very faint when the breaks are released and coasting in gear, but it's not really noticeable. It doesn't happen under acceleration. After that didn't solve the squeak, I did some more testing and discovered that the noise only happens under braking, with the transmission in gear. If the transmission is in neutral while braking, no noise. If I put a fuse in the FWD switch, these is no noise at any time. ATF was last changed about 20k miles ago. Still looks normal. What's making this noise? I think it's possibly the rear transfer case/switch in the transmission, but I sure hope not. I don't see how it would be any of the drive line components, because they still spin even when the 4WD is off.
