JDM 5 speed issues
Posted
So I am in a challenging situation. My 2005 LGT wagon blew the diffs in the stock 5 speed about 5k miles ago. I got a used JDM 5 speed from a 2005 2.0GT, and I had it installed at a dealer (big mistake). Now, I am getting strange noises from this transmission. When sitting in neutral with the clutch out, it makes a faint constant clicking sound. This sound will match the engine speed if I rev the car in neutral. Now when I depress the clutch the noise goes away and there is nothing other than engine when I rev it. I can also hear some strange quiet metal on metal noise when in 2nd gear.
The only issue I have had with this transmission is a grind if I try to put it into reverse too quickly after pressing in the clutch. The grind occurs ONLY into reverse, and only if I attempt to put it into reverse too quickly after pressing the clutch.
All in all this transmission is making too many noises for it's mileage, and having it installed at a dealer I do not know what they did or did not do. They may have reused the old TOB for all I know. And I do not know the gear oil that was put into this transmission.
So any help from experts would be greatly appreciated. Thanks guys!
Posted
im not any expert with trans but i would call the dealer first and see exactly what they did/used i would think they have it all on record, i would hope at least. to me it sound like something isn't just lined up correctly, but what do i know about transmissions? nothing lol
Posted
The dealer used a TSK3 ki which comes with a new TOB, but I do not know what kind of gear oil they used, or what the wear on the clutch and flywheel looked like. The don't tell customers anything :icon_roll
