alex0856 Posted May 18, 2015 Posted May 18, 2015 Hi all, I'm looking to pick up a used hitch from a member here. Does anyone know if sedan and wagon aftermarket hitches are universal? The hitch is one of these: https://www.etrailer.com/hitch-2005_Subaru_Legacy.htm Haven't confirmed the exact model yet, but this site leads me to believe they are universal. Thoughts? Thanks all
DMTaylor Posted May 18, 2015 Posted May 18, 2015 It will mount, although technically the sedan isn't rated for towing, so none (that I know of) are made for it. I have a Hidden Hitch (looks similar) on mine and it worked well for towing a motorcycle nearly 5000 miles total. Dave
alex0856 Posted May 18, 2015 Author Posted May 18, 2015 The member selling it had it on his sedan. Just hoping they mounting points are the same.
Cornerz Posted May 18, 2015 Posted May 18, 2015 I just installed one (same hitch model) on my 05 LGT wagon last week. It hangs low, and will tend to scrape in certain situations. It could have been designed much better to allow the receiver to be an inch higher. Unfortunately it wasn't.
alex0856 Posted May 18, 2015 Author Posted May 18, 2015 How difficult was install? It'd be used very rarely for me so it might be better to remove it when not in use. Do you have a pic?
Cornerz Posted May 19, 2015 Posted May 19, 2015 Super simple. The pics on the etrailer link you posted show the whole job. two bolts above each muffler, one down thru the tow hook at the rear of the spare tire well.
alex0856 Posted May 19, 2015 Author Posted May 19, 2015 Didn't even notice! Well if I run into issues with it hitting my steep driveway, I'll leave it off when not in use.
Dispatch20 Posted May 19, 2015 Posted May 19, 2015 It will mount, although technically the sedan isn't rated for towing, so none (that I know of) are made for it. I have a Hidden Hitch (looks similar) on mine and it worked well for towing a motorcycle nearly 5000 miles total. Dave The LGT and 2.5i sedan have a towing capacity of 2700lbs (3.0R sedan is 3000lbs). I removed the uhaul hitch from my 3.0R sedan because it hung low and dragged on things too often. It's easy to install/remove. I will put it back on when I need it (once a year, maybe).
