BLiTzd Posted May 12, 2015 Posted May 12, 2015 I have a major issue with my rear alignment does anyone know if the front and rear casted camber bolt kits are the same? If not would you please provide me a link so I can buy the correct set. Mine are. Completely buttered to the frame and I need to get then cut off so I need new ones.
ras06LGT Posted May 12, 2015 Posted May 12, 2015 With stock links you cannot adjust rear camber - only toe. Assuming you are actually talking about rear toe, here are the PNs I ordered for my car. Rear cam bolt 901700122 Rear cam washer 903100171 Rear additional washer 20560AA011 Rear locking nut 902350006 Rear toe link bushing 20254AE01A Rear toe link assembly (includes bushing) 20250AE01A I opted to press out the inner bushings and replace them. I pulled the the PN for the full link in case they were seized and I destroyed the link. You will need two of each of the above (one for each side). If your camber in the rear is way out of spec you should inspect further for damaged bushings/links. Hope this helps.
