I3eXa Posted May 4, 2015 Posted May 4, 2015 Broke the front piece of my roof rail off yesterday :mad:and now trying to figure out if I i'm able to just pull down that driver front side of the headliner for those 2 bolts to install a new one once I find one at the junkyard. Any thoughts?
Andy_Mac Posted May 5, 2015 Posted May 5, 2015 Yep. Did my whole liner a few weeks ago. Worth doing the ones behind the main centre light aswell to get a bit more leverage so it doesn't kink. Does have a fair bit of flex to it though Had the rear all connected and the front sitting on the front seat headrests while i fiddled with some wiring, should be enough for what you're after too 2000 Legacy B4 RSK - SOLD 2006 Legacy BP5 GT Spec B wagon - Garage Thread 2011 VW T5 van 2.0L of turbo diesel awesomeness
Max Capacity Posted May 5, 2015 Posted May 5, 2015 Make sure you seal the holes, don't want a water leak. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here
