turbo replace, what else to check/replace?
Posted
Why do you need to replace the turbo ?
If it blew and put metal into the oil system then see above ^. Along with oil pump and oil cooler.
Engine Build - Click Here
Posted
Unless you're replacing the turbo because of a bad waste gate flapper, or as an upgrade, chances are there's going to be a lot more to it than just 'replacing your turbo'... if you do it properly.
But for the sake of your question:
-Replace the turbo coolant feed/return hoses and clamps.(Just flush your coolant while you're at it...)
-Get a new rubber oil drain tube and clamps.
- As Tris said, get rid of those banjo filters ASAP.
-New down pipe/up pipe gaskets
-Get new stainless hardware if you have a hard time getting the existing nuts/bolts off
-Catless up pipe? I think your 2007 is good, someone more knowledgable will chime in.
Thats what I did when I replaced mine, because of a bad waste gate.
If the turbo blew up on you, scrap that list and start planning out your rebuild. 'cuz #YNANSB!
MTBwrench's Stage 3 5EAT #racewagon 266awhp/255awtq @17.5psi, Tuned By Graham of Boosted Performance
Everyone knows what I taste like.
Posted
Play in the turbo, had p0011. banjo bold was clogged. Checked play on turbo, abouy 1/8 inch play, changing before it goes.
Dont believe a need a new block, she still runs great.
Have a cobb exaust and accessport now.
Posted
FWIW, I bolt the turbo to the up pipe, leave it loose until you have the tmic started and the two bolts at the tmic to turbo started, then start the bracket bolts then tighten the TB clamp, then two bolts at the tmic to turbo then the rest.
Posted
Haha, no worries. Just posted in the Vanity Plate section with that as a plate!
Vanity Plate section....where's that ?
Posted
Posted
Are you the first owner? If not, original turbo?
