vtoutback Posted April 23, 2015 Posted April 23, 2015 Hello All, Well, I have a 2005 OBXT and have found myself in the same situation as many before. You've all heard the same story: boy meets car, boy falls in love, boy treats car well, car dies and breaks his f'ing heart. I bought a '97 Outback about 10 years ago, and that's when my relationship with Subaru began. I have driven that car everywhere, coast to coast, in the mountains, in the desert, and all parts between. As she started to show her age, I knew it was time to put her out to pasture and find myself a new workhorse. In a previous time I had been a Nissan man, starting with a Sentra and then a couple Maximas. There were trade-offs when I went from the Max to the Outback, but I found the Subaru fit my lifestyle and needs better than the sedans ever did. As I was looking for a 'new' car, my gaze was pretty firmly fixed on an OBXT. It's all the things I loved about my old OB, plus all the power (and more) that I had been missing since the Maxima! For about a year and a half things were great! When my wife would ask about mpg/premium fuel, I'd tell her sure 'it gets less miles per gallon, but way more smiles per gallon.' Then it happened. I was about 100 miles from home and about 10 minutes away from a client's site, cruise set around 60. I'm not certain about the exact chain of events (as in what died first) but 5 minutes later I was able to limp it to a clear pull off and assess what I could of the damage. It was not good. Longer story, but after I finally got the car back to my house it was confirmed that the turbo was toast and a cylinder was down. So here we are. Old blue has been called back in action as the XT is expected to be in the ICU for a couple months. The car is in my garage and I have begun the deconstruction process. As it sits at the moment, I have the engine assembly removed but have not bought any part yet. I am still trying to figure out what the best step moving forward will be. I have not removed the heads yet, so I don't know if they are salvageable or not. If not, that will greatly effect the decision process. Now that you have a little of the back story, here is the current list of options I'm considering. *Note: this is my daily driver, and little to no performance upgrades are planned at this time. 1) If the heads are salvageable, then proceed to the #YNANSB path and rebuild my engine. 2) If heads are too f'ed, than find a long block / complete engine and do the transplant. or 3) Explore the EJ20X/Y swap over route. This option presented itself to me when I contacted a supplier and they quoted me on a EJ20X. "Hey, I was calling about a EJ255" I say - 'yeah, this is the motor they used in Japan and will fit in your car'. Ok. Interesting. So yesterday I was reading through the boards and started finding info/threads about this project. I would like to gather as much detailed information on this swap as possible to guide my decision. I have been finding several low mileage engines available (with 5mt & ecu), at lower prices and better condition than the 255's I'm finding. I look forward to the community's input and insight. Thanks! Eric
Kelvrick Posted April 24, 2015 Posted April 24, 2015 Long story short, I don't know. Here is a links for you to read if you didn't find it yet. I skimmed it and it doesn't look so bad as long and probably should get a tune after the swap. If you don't mind, would you share how much the ej20x was going to cost you? http://legacygt.com/forums/showthread.php/ej20x-swapi-224284.html My Outback
vtoutback Posted May 26, 2015 Author Posted May 26, 2015 There has not been much to report for the last month or so - all of my weekends have been planned for me and I've had very little time to devote to the car. That said, I did make some progress this weekend. I've basically been in limbo with which direction to go and the engine has been sitting on a tire waiting for me to make a move. I have been leaning heavily toward just buying a re-man long block, so I really didn't want to start tearing down my engine until I had the new block to start building up. After talking to my brother over the weekend, he was like 'just tear it down and get in there - you don't even know if the heads are f'ed or not. If they are, then what's the harm in tearing it down.' Going on that advice, I started into it and took it as far as I could go without special tools. After the kids were asleep I was able to spend a few hours in the garage and pulled the up pipe, crank pulley, intake manifold, wiring harness, and timing belt. Since I really wasn't planning on working on it this weekend, I had to stop for the evening at the cam sprockets [ordered the Company 23 tools this morning]. I also pulled the the driver's side valve cover to have a look at the cams. The surface of the lobes looked mirror smooth. I took off one of the supports / caps and there were some light grooves on both surfaces - I don't know if this is normal wear/tear over time or not. I will post some pictures when I can, need to setup/upload to my hosting site. If I get the cam tools by the weekend, I hope to have the heads off and get them over to a shop next week to see where I stand.
vtoutback Posted June 8, 2015 Author Posted June 8, 2015 Update: I got the heads pulled off last weekend and it looks like they are trashed. I called a couple of machine shops and based on our conversation I had to come to terms with the fact that they are too far gone. I have not split the block yet, but should have that apart sometime this week. Continuing the tear-down, I removed the cooling system, water pump, oil pump & cooler, as well as the oil pan. When the car originally went down, I had it towed to my local mechanic and he dropped the oil pan and found a bunch of metal shavings. He cleaned it out, slapped it back together and filled with oil so I could limp it 2-3 miles home. When I dropped the pan last week, I found a whole new bounty of metal - nearly all of it was iron. At this point I'm assuming I spun the bearings. When I get the block split I will finally see what's left and what's salvageable. At this point, I don't even know if it's worth trying to build back. Short blocks are easy to come by, but I am having a hard time finding B25 heads anywhere. I can find re-man'd long blocks for around $3500-$3800, but still need the clutch, turbo, hoses, gaskets, etc, etc. Honestly, I've been looking at just buying a 2.5i with a 5 speed - cheaper to operate (dd), and I can get a whole car for about the price of what it will cost me to fix the XT. Or if I want to keep the power and lower gas mileage, just find a 3.0R or an LL Bean...
Nightmaresmk Posted June 9, 2015 Posted June 9, 2015 Buy an NA and build the turbo. sad that some people just don't take care of these cars like they need.
vtoutback Posted June 22, 2015 Author Posted June 22, 2015 There has been little to no work put in this car since my last post. I've cleaned up pieces and bagged/tagged a bunch of parts, but that's it. I did, however, pick up an '03 LL Bean on Friday. This is not treason. The Bean will allow me to rebuild the XT. The '97 has done a solid job as the daily driver for the last few months, no question. However, it's not a viable solution for the realist time frame it will take me to rebuild. In the meantime, I plan on taking some family road trips with the '03 and worrying less about cars for little while.
