throwout bearing "snugness"
SSpeed
Posted
I have the engine out of my '99 Outback. Clutch friction disk and pressure plate were good, but the throwout bearing sounds awful. I got a new one (right part #) but it has play on the input shaft sleeve. I can move the bearing up and down probably at least 1/16th of inch. I got rid of the old one before I noticed the play, so I can only assume it had play as well.
How much play is too much? I don't think there is enough room for a sleeve. This is just the sluggish 165hp EJ25d, so tolerances are a little more forgiveable.
Posted
Thanks, that's what I was thinking. Holy moly, $150 is crazy for a throwout bearing and aluminum sleeve.
Posted
I think the sleeve is machined stainless steel, which isn't too crazy in price for that. It might seem a lot, but it's better than a damaged transmission casing if it fails.
Posted
Actually it looks like it is $209 for the 2005 model !!!
Posted
$20 speedi sleeve is all that's needed.
Can get on Rock Auto or maybe local parts store.
But it is best to do something, it may bind on you if nothing is done. It's only going to get worse left like that.
Posted
I think that sleeve may be for the shaft seal, it is only 11mm long. Here is the link to the dimensional drawing of that sleeve :
http://www.skf.com/us/products/seals/industrial-seals/power-transmission-seals/wear-seals-skf-speedi-sleeve/index.html?prodid=791701023&imperial=false
I don't know the dimensions of your transmission snout, to be able to find the correct sleeve.
My 2005 had some wear on the snout, I greased it and put it in. It seems to be working probably repairing it would of been better.
At least you didn't wait as long as I did :
Posted
There should be some gap. put a small amount of high temp grease on the snout and slide the new TOB on.
PM "underdog" and ask him for guidance...oh yea. you should buy your parts from him also.
Mike at www.AZPinstalls.com is another good source.
Engine Build - Click Here
