05 Legacy GT Limited questions
Posted
Cross post from Pre-Purchase questions
Well here I am about a few hours away from driving out of town to pick up a legacy I've been eyeing for a little over a month.
Mileage: 97000
It has a stage 2 tune with magnaflow Catback exhaust, k&n Air filter, catless up pipe, fresh clutch job, hks blowoff valve.
More than likely due for timing belt in 3k miles.
No word on the banjo bolt filter, I don't believe it's been replaced, I understand that the turbos turn into grenades when they don't have banjo/uppipe, but is there anything else I should know?
Posted
I hope you got a compression and leak down test before purchasing. Make sure to remove the banjo and check the turbo for shaft play.
