Posted
I'm getting this intermittently, and the engine is also intermittently shutting off while I'm driving down the road. It might be on the highway, and it might be on a surface street at 35mph. This last time, there was no response when I put into 3rd to start it when I slowed down, and I had to sit for about a minute before it would start back up. I am running a little rough, off and on, and sometimes it will clear up on its own.
p0335 Camshaft position sensor "A" circuit.
This is sometimes associated with misfires on various cylinders(1,2,3 tonight)
Posted
ya id at least check the sensor to at least make sure it isnt loose or jacked up. i replaced mine with a junkyard one i had, solved the issue with intermittent no start.
