Sleepr56 Posted August 7, 2012 Share Posted August 7, 2012 2013 Legacy & Outback Bulb Guide: http://img.photobucket.com/albums/v452/sleepr56/Legacy%2036R/IMG_2062.jpg http://img.photobucket.com/albums/v452/sleepr56/Legacy%2036R/IMG_2063.jpg http://img.photobucket.com/albums/v452/sleepr56/Legacy%2036R/IMG_2064.jpg Link to comment Share on other sites More sharing options...
kfig5 Posted September 10, 2012 Share Posted September 10, 2012 Hi all, I just picked up some Philips Crystal Vision Ultras for my DRLs and Low Beams for my 2013 Legacy. I'm looking to get some LED Switchbacks for my Turn Signals, but am wondering if I should bother changing the Parking Lights to LED as well so they're a closer match? Thoughts? I'm looking at the bulbs here, but not sure which ones to get. http://www.superbrightleds.com/cat/led-vehicle-replacement-bulbs/vehicle/2012-subaru-legacy--parking+light/59-675--526915/ Link to comment Share on other sites More sharing options...
JJr Posted September 22, 2012 Share Posted September 22, 2012 I just installed Oscram H7 65w low beams and Narva H3 55w fogs, huge difference IMO the way to go! Link to comment Share on other sites More sharing options...
jonnyb Posted February 15, 2014 Share Posted February 15, 2014 So I just installed 7664 Cree LED's in my reverse lights on my 09 LGT and now when I put my blinkers of they blink rapidly as if they were close to dying, headlight side mirror and taillight are all blinking fast, does anybody have any insight on this problem? I know it says 921 is our reverse light but when I ordered it it was way to small and the 7664's were bigger and fit Link to comment Share on other sites More sharing options...
A_Tang Posted July 7, 2014 Share Posted July 7, 2014 (edited) DON'T take the headlights out. Undo the pop-its from the wheel well liner. any of them from the axle line forward, and pull the wheel well liner out a bit, so you can reach behind it. there is at least a couple under the front apron area. be careful not to break them, although if you have some extra pop-its, some stubborn ones it is easier to just break off, and pull out. With some nimble fingerwork, and some patience, you can rotate and pull the indicator socket out, and pull the bulb out of it... you may want to hold the bulb in a certain orientation as you bring it out of the wheel well area, and note which side of the bulb the writing is on that says what bulb number it is. do the same for the bulb you are putting in, because it will be blind work when you put it back. you may want to test to make sure they work correctly before you button the wheel well liner back in on each side. I did it (with silverstar indicator bulbs) while I was changing oil and tires over for the winter, which gave me a lot more room to work, with the car on jack stands, and the front wheels off already... Sorry to revive such an old post, but I just tried to change out my front turn signal/marker bulbs (for LED units). The passenger's side went without a hitch when reaching into the wheel well, but on the driver's side, there's a auto trans filter and what look like washer tank and trans fluid lines all in the way. Will I have to remove the bumper cover? Or should I try removing the battery? Also wanted to add some info that I just discovered regarding the front turn signals: http://legacygt.com/forums/showpost.php?p=4868376&postcount=11 Edited July 9, 2014 by A_Tang Link to comment Share on other sites More sharing options...
whiteknight24 Posted August 7, 2014 Share Posted August 7, 2014 hey what do people recommend for the best fog light bulbs? Should I go 3000k or higher? any preference with housings also?? Link to comment Share on other sites More sharing options...
A_Tang Posted August 13, 2014 Share Posted August 13, 2014 hey what do people recommend for the best fog light bulbs? Should I go 3000k or higher? any preference with housings also?? I prefer a yellower light color for the foglamps. I wasn't trying to match my lowbeams, so I actually put yellow film over my foglamp lenses. Link to comment Share on other sites More sharing options...
MountainScooby Posted August 18, 2014 Share Posted August 18, 2014 The silver looking bulb that lights up the Gear indicators as circled in the picture? Link to comment Share on other sites More sharing options...
oaklandmiLGT Posted November 2, 2014 Share Posted November 2, 2014 If you install a higher voltage and wattage bulb than recomended will that allow too much energy to flow, allowing the wires and/or bulb to get too hot? Link to comment Share on other sites More sharing options...
ssbtech Posted November 2, 2014 Share Posted November 2, 2014 Generally over wattage bulbs are a bad idea, but most of us have been fine with 65w bulbs for the low and high-beams. Link to comment Share on other sites More sharing options...
Heffernan Posted November 18, 2014 Share Posted November 18, 2014 Anyone know if the front turn signal bulb listed for an '05 Lagacy on the first page (3157A) is the same as an '08 Outback? Link to comment Share on other sites More sharing options...
khaos_65 Posted May 18, 2015 Share Posted May 18, 2015 Does anyone have a picture of a 5th gen with piaa XTreme 9005 bulbs? Link to comment Share on other sites More sharing options...
ssbtech Posted July 13, 2015 Share Posted July 13, 2015 Map light, Dome light DE3175 Just bought two bulbs marked "fits 3175" and they're too long for the map light. Should have gone with my gut feeling and bought the 30mm bulb. Link to comment Share on other sites More sharing options...
ssbtech Posted July 15, 2015 Share Posted July 15, 2015 Crap, the 30mm is too big as well. And it's the smallest the store had. Link to comment Share on other sites More sharing options...
spad Posted October 28, 2015 Share Posted October 28, 2015 does anyone know part numbers for low beam reflectors and whether its possible to get them somewhere? i have a 3.0r from 2005 and one of my low beam lamps came loose and actually burned through one of the reflectors... would be a shame to exchange the whole assembly because of that... Link to comment Share on other sites More sharing options...
RBJ Posted June 13, 2016 Share Posted June 13, 2016 Can you give me the LED specs for 2012 Models please? High Beams / Low Beams And how to turn off Day Time Running Lights. Link to comment Share on other sites More sharing options...
NateSubzLGT Posted September 28, 2016 Share Posted September 28, 2016 Has anyone changed their puddle lights? if so what did you use? 10' LGT Limited Link to comment Share on other sites More sharing options...
ethanrbutler Posted September 5, 2017 Share Posted September 5, 2017 Don't buy zevo bulbs, they are garbage. Spend 60% the amount and buy standard Sylvania leds if you insist on buying local, they are brighter and give off fuller light in the interior. Trust me Link to comment Share on other sites More sharing options...
Drzazgatron Posted September 20, 2019 Share Posted September 20, 2019 I'm having trouble with the "how in God's name does this stupid bulb go in this GD thing!?!?" Got an after market blub (only bulb, has a cord) doesn't look anything like the 1 I pulled out (bulb attached 2 plastic fitting). If the bulb in the fitting comes out idk how 2 remove it and almost b4oke it. Could some1 please help me out and clear up some of the who, what, when, where, and why? Please and thank you, Drzazga Link to comment Share on other sites More sharing options...
max_bobby Posted December 5, 2021 Share Posted December 5, 2021 Has anyone tried led bulbs headlights for 08 leggy? Link to comment Share on other sites More sharing options...
ssbtech Posted December 5, 2021 Share Posted December 5, 2021 Has anyone tried led bulbs headlights for 08 leggy? Just don't. Link to comment Share on other sites More sharing options...
Cheeto9 Posted February 21, 2022 Share Posted February 21, 2022 nice info Link to comment Share on other sites More sharing options...
GearJamr Posted February 22, 2022 Share Posted February 22, 2022 Just don't. Completely agree. wasted my money on them. Just get the 65W bulbs and call it a day. Link to comment Share on other sites More sharing options...
