2010 lgt 6mt-how much hp is safe?
garygbnj
Posted
Getting a stage I tune. Depending on the tuner can generate as much as 60 hp increase (much increased psi in 1,2,3rd gear. How much increase in hp can the trans safely take? Transmissions are expensive to rebuild.
Gary NJ
Posted
Granted you have a 6mt but it's not the same as the real 6mt in the STI's and lesser Spec B's.
I do agree you'll be fine till you get ^ like he said.
The clutch is next thing you'll have to worry about.
Engine Build - Click Here
