wileycoyote0022 Posted March 22, 2015 Posted March 22, 2015 I don't know about most, but sometimes it hard to find a car that hasn't seen northern salt, and just about every nut and bolt under the car is rusted. After the second time I turned a wrench on my car, I couldn't stand it any longer. So I finally compose the list of nuts, bolts, and washers that see get the most weathering; suspension, chassis, motor mounts, transmission mounts, and a few others. The description is just to give you an idea of the location, cause I'm sure its not "technically" correct. There were a couple part numbers/prices I couldn't find. Description_____________Part Number____Qty Transmission Bolt & Washer Bell House (2 L, 2 R)_____800510080______4 Bolt & Washer Bell House (top L & R)____800510060______2 Bell House Nut (lower L & R)___________802010080______2 Bell House Washer (lower L & R) _______803010120______2 Mounts and Drivetrain Dynamic Damper Bolt (CM)____________010006350______2 Cross member Bolt (center) ___________20540FC110 ____2 Transmission Mount Bolt______________ 901120096______6 Transmission Mount Nut_______________?????___________4 Cross member Bolt (rear)______________901030002_____6 Cross Member Bolt (rear plate)_________?????__________2 Engine Mount Washer_________________903100168______2 Engine Mount Nut____________________902370028______2 Engine Mount Bolt____________________901120096______6 Brakes/Hub/Shock Front Brake Flange Bolt_______________901000316______4 Front Hub Flange Bolt_________________901000238______8 Rear Brake Flange Bolt________________26273AC001____4 Rear Hub Flang Bolt__________________901000258______8 Suspension Rear Rear Nut (lateral Links)_______________902350022______10 Rear Cam Bolt_______________________901700122______2 Rear Cam washer____________________903100171______2 Rear Toe Washer ____________________20560AA011_____2 Rear Lateral Bolts____________________901000110______6 Rear Lateral Bolts (outter)_____________901000244______4 Rear Trailing Arm Bolt________________901000175______2 Rear Trailing Arm Bracket Bolt_________901000178______8 Rear (lower) Strut Bolt________________901000177______2 Rear (lower) Strut Washer_____________900335062______2 Rear (lower) Strut Nut________________902350021______2 Rear Sub Frame Bolt__________________901000252_____8 Rear End Link Nut Upper_______________902370029_____2 Rear End Link Nut Lower_______________902370046_____2 Front Front Strut Bolt______________________20540AA100_____2 Front Strut Cam Bolt__________________20540AA090_____2 Front Strut Nut_______________________20550AA010____4 Front Strut Washer___________________20560AA040_____2 Ball Joint Bolt________________________901000060_____2 Transverse Link Plate Nut______________902350023______2 Transverse Link Plate Bolt_____________901030007 ______4 Transverse Link/Cross Member Bolt_____901000264______2 Transverse Link/Cross Member Nut______902350006______2 Support Arm/Cross Member Bolt________????___________6 Support Arm/Cross Member Nut_________????___________2 Crossmember Bolt/Body_______________901000242_____4 Front Endlink Nut_____________________902350001______4 Front Top Hat Nut____________________902350013______6 __________________________________________________164 Total Cost: $323.43 including shipping I used opposedforces.com/parts , to look up part numbers. I know there are alot of subaru oem online part stores, but I liked this one the best IMO, easiest site to navigate. Second site was http://www.subarupartsdepot.com . They had the best prices all around that I could find. I hope this helps someone.
wileycoyote0022 Posted March 22, 2015 Author Posted March 22, 2015 Rear Sub Frame Bolt__________________901000252_____8 If you want to cut a large chuck of the price down, the Sub Frame Bolts are $5 a piece (8 total of them), so its $40. So unless you are changing the subframe bushings too, cut those out. Total $283 http://www.hptmotorsports.com/images/detailed/7/KDT922-2.jpg
theflystyle Posted March 23, 2015 Posted March 23, 2015 Good info. Just thought I would add that quirkparts.com has recently been my go-to for OEM. They have been cheaper for all the parts I have been shopping for both my SVX & 3.0R.
cheeseenlo Posted March 23, 2015 Posted March 23, 2015 Which subframe bushing kit is that? Rear Sub Frame Bolt__________________901000252_____8 If you want to cut a large chuck of the price down, the Sub Frame Bolts are $5 a piece (8 total of them), so its $40. So unless you are changing the subframe bushings too, cut those out. Total $283 http://www.hptmotorsports.com/images/detailed/7/KDT922-2.jpg
Diesel_Jeremiah Posted October 7, 2016 Posted October 7, 2016 Rear Sub Frame Bolt__________________901000252_____8 If you want to cut a large chuck of the price down, the Sub Frame Bolts are $5 a piece (8 total of them), so its $40. So unless you are changing the subframe bushings too, cut those out. Total $283 http://www.hptmotorsports.com/images/detailed/7/KDT922-2.jpg Which subframe bushing kit is that? It's the Whiteline kit, though on no website anywhere does it say which on fits the 05-09 LGT. Do you still have the kit number? Evolution of a Dream
Max Capacity Posted October 7, 2016 Posted October 7, 2016 See post #128 cheaper price for these. http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238p4.html 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here
Diesel_Jeremiah Posted October 7, 2016 Posted October 7, 2016 See post #128 cheaper price for these. http://legacygt.com/forums/showthread.php/idea-web-links-saved-various-parts-219238p4.html I should have clarified. I'm looking for the bushings. Sent from my One M8 using Tapatalk Evolution of a Dream
Max Capacity Posted October 7, 2016 Posted October 7, 2016 I should have clarified. I'm looking for the bushings. Sent from my One M8 using Tapatalk If your looking for bushings, I see your on the west coast, just pm "m sprank" or go to his web site http://www.infamousperformance.net Tell Mike I sent you. He'll give you get customer service and well sell you what he knows works. It's takes all the stress out of buying things for your car when you buy from one of the trusted members here. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here
JmP6889928 Posted October 8, 2016 Posted October 8, 2016 Thanks much for this list. I took the liberty of inserting it into my IDEA sticky above so everyone can find it.
