Vetteman Posted December 24, 2014 Share Posted December 24, 2014 Having had to drive through real fog the other night, I hereby declare the fog lights totally useless. Not because of low power, etc. but because they are linked to the low beam circuit. In a real fog, the low beams just reflect back and the fog lights do nothing for you because of all the glare from the low beams. Whoever came up with this setup has obviously never actually driven in fog. So my question is, how do I make them work independently of the low beam circuit? The Vette allows me to drive with the fogs on, as long as the marker lights are on, and I am not on high beam - that is what I would like to achieve, as it is perfectly legal. Or just make that circuit totally independent. For my annual inspection, no one has ever tested the fogs, so though illegal, I could live with it. Link to comment Share on other sites More sharing options...
MrTris Posted December 24, 2014 Share Posted December 24, 2014 See the Walkthroughs section. . Link to comment Share on other sites More sharing options...
Akasa Posted December 24, 2014 Share Posted December 24, 2014 Same idea as this. This is what you want to do to make your fog lights run with your parking lights. Make sure you disable your DRL if you truly want to run only fogs. Try searching Google next time with the site tag site:legacygt.com. Link to comment Share on other sites More sharing options...
bluesuby Posted December 26, 2014 Share Posted December 26, 2014 Having had to drive through real fog the other night, I hereby declare the fog lights totally useless. Not because of low power, etc. but because they are linked to the low beam circuit. In a real fog, the low beams just reflect back and the fog lights do nothing for you because of all the glare from the low beams. Whoever came up with this setup has obviously never actually driven in fog. So my question is, how do I make them work independently of the low beam circuit? The Vette allows me to drive with the fogs on, as long as the marker lights are on, and I am not on high beam - that is what I would like to achieve, as it is perfectly legal. Or just make that circuit totally independent. For my annual inspection, no one has ever tested the fogs, so though illegal, I could live with it. I've driven in lots of fog and snow and I can tell you high beams are a problem with reflection. Running fog lights alone might give you that gangsta look, but will neither provide sufficient illumination nor give approaching drivers fair warning they are coming up on you. Link to comment Share on other sites More sharing options...
Vetteman Posted December 27, 2014 Author Share Posted December 27, 2014 You missed my point - it's not just the high beams reflecting - the low beams reflect too much in heavy fog too. I am not talking about "mist" or light fog, I am talking about running into a wall of the white stuff where your visibility is at best 10-20 feet, which I did on the way home recently. BTW, I have no interest in a "gangsta" look (whatever that is, I am sure a LGT Wagon is not it), I just want to be able to see the sides of the road. Too much to ask? The "fog lights only" setting works OK in my Vette in heavy fog. On the Legacy, the fogs are totally useless under those conditions. Link to comment Share on other sites More sharing options...
HDTurbo Posted December 27, 2014 Share Posted December 27, 2014 I guess sometimes your just screwed and have to feel you way along the road. Had to slow to a crawl recently in an unusually warm night where thick fog rolled across the road from the snow on the fields. I wonder if red lows/fogs lights would be better! Link to comment Share on other sites More sharing options...
MrTris Posted December 28, 2014 Share Posted December 28, 2014 3k fogs exist for a reason. Link to comment Share on other sites More sharing options...
danci1973 Posted December 29, 2014 Share Posted December 29, 2014 On my EDM Legacy I can use just the fog lights by switching the main light switch in the middle position ('marking lights'). Just yesterday I was driving in a blizzard and tried it out and I think you'll find them even more useless on their own. I ended up adjusting the main bean down and it was much better. Link to comment Share on other sites More sharing options...
