gimpydingo Posted December 23, 2014 Share Posted December 23, 2014 More projects! My 07 LGT has about 85k miles on it and I'm finding quite a few projects to undertake; leaky diff, sway bar bushing replacements, hose replacements, the typical bs. Changing the oil and looking up towards the turbo there is a heat shield on a pipe underneath it that is in two parts and the weld has broken, so it's loose. Not enough room to get tools in there to remove and I don't see a way to use a hose clamp to hold it together. I was looking around at steel putty's/jb weld to hold this in place and seems the high heat is only around 500 degrees. I did end up finding these which seems like an option: http://www.aremco.com/news-item/pyro-putty-2400-high-temp-metal-sealer/ http://www.cotronics.com/vo/cotr/rm_putties.htm Thoughts? Link to comment Share on other sites More sharing options...
Max Capacity Posted December 23, 2014 Share Posted December 23, 2014 The pipe under the turbo is the up pipe. Have you tried to wrap some safety wire around it and twist the wire tight ? I used DEI heat wrap on my up/dp and stock manifold where I've removed the stock heat shields. 305,600miles 5/2012 ej257 short block, 8/2011 installed VF52 turbo, @20.8psi, 280whp, 300ftlbs. (SOLD). CHECK your oil, these cars use it. Engine Build - Click Here Link to comment Share on other sites More sharing options...
gimpydingo Posted December 23, 2014 Author Share Posted December 23, 2014 Yeah, I think it is the UP. I could try wrapping wire around it. Is there an easy way to get the shield off without tearing apart the car? Seems to be a tight fit. Since I can see the weld on the bottom I figured a dab of the putty might hold it. I did email both companies to see if they will send me a sample any way. Waiting for the dealer to be done looking at the car. They are saying no vac leaks, my trims are off though....fun fun Link to comment Share on other sites More sharing options...
