asylum Posted December 22, 2014 Share Posted December 22, 2014 On my 3.0R MT... Since I own my car (50 kmiles and many oil changes), every winter I sometime have a P0011 code that comes on and disapear. I also have a strange behaviour since I own it : sometimes when I shift to upper gear, I have a delay of up to 2 seconds between the time I press the pedal and the car accelerates. I mean : I press the pedal after shifting, the car accelerates slowly (abnormaly slowly) and then 2 seconds later suddenly it begins to accelerate normaly. Most of the time this happens when rpm after shifting is 3000 - 4000 rpm. Do you think the two are linked ? What do you advise ? Clean right OCV or replace it ? Link to comment Share on other sites More sharing options...
MrTris Posted December 22, 2014 Share Posted December 22, 2014 How long since you've changed the oil? If it's been awhile, change the oil and reset the ECU. IF the code comes back, then look into replacing the OCV. Link to comment Share on other sites More sharing options...
asylum Posted December 22, 2014 Author Share Posted December 22, 2014 2 or 3 kmiles max. But as I said, this happens since I have it, independently of the oil changes I have made. Link to comment Share on other sites More sharing options...
MrTris Posted December 22, 2014 Share Posted December 22, 2014 2 or 3 kmiles max. But as I said, this happens since I have it, independently of the oil changes I have made. Then in that case, look into replacing your OCVs. Since you are well outside the US, I can't recommend a proper vendor or acquisition method, I'm afraid. Link to comment Share on other sites More sharing options...
